I had a bad problem with PF and cured it with Birkenstock arch supports and a night splint. These are the insoles** **http://catalog.birkenstockcentral.com/vc3bc/partnumber/^9210$/template-b// . I have had 2 pairs for about 6-8 years and they show no signs of wear. I had 3 pairs of custom made orthotics made by podiatrists and the Birkenstock inserts are far superior IMHO. I also never walk around my house barefoot. I always were sandals (yes, Birkenstocks).
Here’s a picture (the closest I could find) of a low-Dye taping (okay, I found the correct spelling). But what’s shown here isn’t quite what I’ve been doing (and was how I was taught to do it some 25 years ago).
What I do is use the standard 1" or so wide cloth athletic tape, and tear off two lengths that will go from the ball of my foot, around the back of my heel, and then up to the head of the 5th metatarsal (the base of the little toe). I then tear each of these in half length-wise. These long strips attach to the ball of the foot, around the back of the heel like it’s shown in the picture (and this is where the varying tension can be made), and then up to the base of the little toe. I vary the first attach point on the ball to encompass the ENTIRE ball of the foot on each long strip. Then I use full-width strips going across the bottom of the foot, first to secure the ends of the length-wise tape, and then to bring the “bow-string” part that’s spanning the arch into the foot. I don’t wrap all the way around the foot like is shown in this picture. Seems to hold pretty well, and can do everything from holding the arch up almost rigidly (and being a little bit painful with the pulling on the ball of the foot) to just slightly tensioned (giving the arch some support).
Hope that helps (and isn’t too confusing).
BUT… with all that said, I’d get the okay from a qualified medical professional.
I was told Superfeet was good for couple of shoes so about 500-600 miles maybe? It should be on the manufacturer page. i know you can bake custome Sole insoles up to 4 times.
Based on your post it appears you replace your shoes every 250-300 miles?
I do 500 miles per pair of shoes running 99% asphalt road.
I went on Superfee’s website and I did not see any mileage guide.
In their user guide says “depending on the activity Superfeet lasts 12 month or longer”
Thanks. My PF is not too bad. Maybe I will have to try a pair and see if it makes a difference.
Green superfeet has solid support but I liked the molded Soles better you can heat and hold in your shoe. Trisports has them and you get 15% slowtwitch discount on those I believe.
http://video.google.com/videoplay?docid=8017730526604136092
Try that. I am going to get some tape tonight and give a a try in the next couple of days.
Good Luck,
Paul
The first time I had it done was for splinting the foot to allow ligaments to “re-tighten” after I dislocated my cuboid. Never had anything crossing diagonally under my foot like he shows. So I’m thinking there are several different ways to do it.
