Can anyone point me toward an air pump - floor and/or mini - that fits into the valve slot on the HED3’s so that I don’t have to use the crack pipe? I carry CO2 for races, but I need something for training and when I’m on the trainer. If you know the specific model number (or can provide a link) that would be ideal. Thanks.
I have the same wheel and you want something called the micro-inflate, it is basically a “crack” pipe and you screw the co2 right into it and then you can inflate the Heds
Above works. OR… Just get the presta/shreader adapter. The problem w/ floor pumps is that the large nozzle is on the outside; just put the adapter in there and you should be fine. Worked w/ my HED3s at least.
I found a older hand pump with the slinky fibre covered hose. It doesn’t have the large end that current pumps have. You cn probably find one at garage sales/flea markets.
The Topeak “Joe Blow Sport” floor pump works perfectly as the head of the pump fits right in and inflates without any adapters or crackpipes on my Hed3 and disk. I found it purely by accident as it was the first pump I ever bought, but has done everything I ever needed. I bought it locally at an REI store, but you can also buy online at www.rei.com. Hope that helps
Rob
something that I have always used for my tri spoke wheels and disk wheels is using a screw on valve stem adapter. The kind that is about 2 inches long. That gives you just enough room to use a regular pump outside the cut out.
I use the Topeak “Joe Blow Pro” floor pump and this works perfectly with my Hed3’s. No adapters required.
Thanks for the help guys. I ordered a Joe Blow Pro. BTW, Amazon has it for about $10 less than REI.
Wow I feel pretty dumb today. This past weekend I inflated my Hed3s for the first time, using my Joe Blow pump which I’ve had for years and didn’t even try using it without the adapter.
I was complaining about pumping up to 110psi with one hand. Haha!
I know what I’m going to try tonight!
Can you elaborate? How does that work?
