I just recently picked up a power tap, and was wondering what differences people observe between wattages (say 30 min threshold test) with and without a fan. Also, I’m curious about the same measurements comparing the wattages of indoor (w/or w/o a fan) and outdoor riding. Evaporative cooling is a beautiful thing, and I’m thinking of getting a fan for when the weather will go to crap and I’m driven indoors here in New England.
I’ve never “tested” with or without a fan so I can’t speak to that.
Outdoors vs indoors will vary from individual to individual but my FTP is about 7% higher outdoors (it’s not quite 10 but more than 5 so I use 7). I also find my cadence in the same gear and same power to be about 5% higher outdoors vs indoors.
It sucks…I do most of my riding indoors though. I have one fan (wish I had another) and just work off what my “indoor” FTP is. When I ride outdoors, it’s way easier to hold the wattage.
I wouldn’t even try to ride without a fan. I’m only on the trainer when it’s under 30F and/or snowing here in Ohio. I always have at least 1 window open and a fan in the window. So I’m getting the evaporative effect of colder air.
I still sweat loads…although I put out a fair number of watts I’ve done 2 hour rides in rooms with other riders that weren’t nearly as cool, and my watts were at least 10% lower. I ride the same watts indoors and out. Even though I don’t watch it, my hr ends up being about the same too.
I do a lot of riding indoors. The best thing you can do is get a powerful fan, and point it right at your face. A “30 minute threshold test” without a fan would be near impossible for me. I’d wager at least 20% less wattage if I could suffer through it.
I have been using a CycleOps 300PT trainer for a couple of years with a small oscillating fan that I position so that it blows on my back since I seem to get the most benefit from that direction. Recently, I bought a fan at the local Home Depot for $60 that sits on the floor in front of me and blows like a hurricane on my front side in addition to the rotary fan still blowing on my back. Both are angled about 20-30 degrees so they aren’t blowing at each other. I am pretty sure I can do 5% higher watts simply after adding the second, big fan. Might be more, but it’s hard to tell since I have picked up some fitness along the way too. Even with the additional fan, I put out more watts on the street on my road bike than on the trainer. Probably another 5%.
It’s definitely worth the investment because your body has to redirect blood flow away from your working muscles to your skin in order to get your body cooled down. That means you don’t get as good a quality workout.
x2. If you’re not using a fan, you’re getting an inferior workout.
I’ve never experimented riding the trainer without a fan. I don’t know why you would. I use a Lasko 24" vortex fan and it seems to get the job done. If I really feel warm I have a 5000 cfm work fan that is like a mini hurricane, but it’s almost too much wind and it’s really loud. My indoor and outdoor wattages are the same for seated efforts. Out of the saddle, hard efforts are not the same indoor vs outdoor due to the bike being fixed on the trainer. I can’t even come close to hitting the same sprint wattages indoors vs outdoors.
Absolutely get a fan. I recently got an 18" Air King that puts out a
pretty good volume of air. Definitely makes a difference.
You’ll see lots of different reports about peoples indoor and outdoor
wattage. I find that for me it is largely a matter of attention. Outdoor
I don’t need to pay much attention to hit a pretty good % of my FTP
during a ride. I just ride. Indoor, if I’m not staring at my watts, I seem
to let up a bit without meaning to. I’ve managed pretty good 20
minute test numbers indoor though if I stare at the watt output the
whole time.
