Average power doesn’t tell the whole story. How did you pace yourself? both times the same or did you this time around spend more time both above and below your avg. power output?
With the numbers given I would expect you to be about 1mph faster. Maybe a tiny bit more. But definitely not more than 1.5mph. That’s just from my personal riding experience with my Powertap.
It could be that your numbers aren’t accurate. I zero my Powertap on every other ride, it’s easy and fast and ensures that I get good numbers. That could definitely be an issue since you mentioned that the PT zeroes itself. IT DOESN’T.
Did you race with the exact same gear? If not, that could also be part of the answer to your question.
If your Power numbers are correct, then you have much to improve from an aerodynamic perspective. I ride faster at that power output, but I do have an agressive position on my p3.
…That could definitely be an issue since you mentioned that the PT zeroes itself. IT DOESN’T.
Actually, it does…as long as it’s not TOO far off and you actually coast at some point. It’s pretty easy to check if it’s zeroed by just looking to see if it displays zero power when you coast. Seeing as how I start out every ride with my PT with a coast down my driveway and down the street, it’s pretty easy to see if it’s reading zero or not as I’m heading out.
I’ve had my PT wheel for ~8 months and I’ve probably manually zeroed it only about 2 or 3 times, and it actually didn’t NEED it then either. I was just doing it to ensure everything was reset before checking the torque calibration with a “stomp test”.
IME, the “autozero” function works pretty well…YMMV
The average “in-shape” person can produce about 3 watts/kg for more than an hour (e.g., around 200 watts for a 70 kg rider), with top amateurs producing 5 watts/kg and elite athletes achieving 6 watts/kg for similar lengths of time. Elite track sprinters are able to attain an instantaneous maximum output of around 2,000 watts, or in excess of 25 watts/kg; elite road cyclists may produce 1,600 to 1,700 watts as an instantaneous maximum in their burst to the finish line at the end of a five-hour long road race. Even at moderate speeds, most cycling energy is spent in overcoming aerodynamic drag, which increases with the square of speed; therefore, power needs increase approximately with the cube of speed.
Man and it’s killing me to get to 4w/kg! (sitting on 3.9 as of yesterday’s test)
I got from 3.8 to 3.9 from losing 4lbs! (small rounding in the 100ths)
I’m 6’4" and 181 now, and really don’t want to lose anymore. Then I start thinking, well Mt Washington is next week, I could do a small starvation diet and crack 4.
Same gear both races. While I’m sure there’s room for improvement. I’m pretty confident that my position isn’t exactly horrible.
(never have figured out how to post a pic on this place)
The first pic is from last year, but the position is the nearly the same. The only difference is that I’ve rotated the extensions slightly to bring my forearms parallel to the ground. The second pic is from The Rookie this year.
Gee, I wonder where they got those numbers?
if i understand this correctly, aero drag increases exponentially (to the 2nd power, squared) so to maintain speed as drag increased you would have to increase power ^2.
but if you want to increase speed then you have to overcome drag and apply more power to go at a faster speed. that combines to approxiamet the cube.
IOW. if you are in a vacum then you increase in speed is linear to power, 1:1 : but if you are on the road then you have to increase power to increase speed and overcome the increased drag so you are approximately at the cube.
is that right?
edit: italics added, i understand ‘exponential’ is not necessarily ^2 but any ^. i used it as squared (as opposed to cubed)
Speed and power are more than exponential, they are almost to the cube.
Uhh, speed and power aren’t “more than exponential.” They are exponentially related. Power is proportional to v_ground*v_true^2. Doesn’t matter whether v_ground=v_true or not, it’s still an exponential relationship, not “more than exponential.”
I accept the criticisms of my words. I had expected him to mean that speed and power had a “squared” relationship, which is why I said “more than exponential”. Exponential is exponential, whatever the power. Properly chastized I am.
if you are in a vaccuum you can go any speed with any power
If you are in a vacuum, you can remove aerodynamic drag from the equation of motion. However resisting forces still exist. Although much smaller, rolling resistance and mechanical friction still have to be overcome.
*I accept the criticisms of my words. I had expected him to mean that speed and power had a “squared” relationship, which is why I said “more than exponential”. Exponential is exponential, whatever the power. Properly chastized I am. *
I suggest you google up ‘exponential’ and ‘power law’ distributions.
Francois in Montreal
I don’t quite understand what I missed in the concept? My comment came about because of a poor choice of words in that I presumed he thought speed and power varied as the square (which is why, I presumed, he thought his numbers didn’t fit) and I tried to say it was “more than that”, varying closer to the cube (although it is not an exact relationship as it involves both air and rolling resistance).
Is there something more to the relationship that I don’t get?
I don’t quite understand what I missed in the concept? My comment was related to a poor choice of words in that I presumed he thought speed and power varied as the square (which is why I presumed, he though his numbers didn’t fit) and I tried to say it was “more than that”, varying closer to the cube (although it is not an exact relationship as it involves both air and rolling resistance).
Although I understand the point you are trying to make, your statement ‘*Exponential is exponential, whatever the power’ *makes no sense.
Here’s the difference
Exponential function: P=a exp(bV) or if you prefer: P=a e^(bV)
Power function: P=a V^b
(P=power, v=velocity, a and b are constants)
Velocity is NOT exponentially linked to power because the link is not described by an exponential function. Mathematics is a very precise language. Although these functions may look similar in some cases they are very clearly not the same. Although this may seem like minor detail, trust me, for a physicist, an engineer or a mathematician there is a huge difference there.
