Improving my swim (realistic goals?)
Over the course of this past training season, I made consistent improvements to my swim. There was no formula behind it - just building endurance/speed over time and sustaining good stroke mechanics. Pool availability kept me limited to 6-8k yds/wk for most of the season, which I felt was largely insufficient. Since my workouts were often short and sporadic, I devoted a fair amount of time to speed work (e.g. 50s, 100s, locos).
Using periodic 2k time trials, I saw my average 100yd pace drop by a little more than 10s - equating to roughly 3 1/2 minutes for a HIM swim (not earth shattering, but progress nonetheless). My swim volume actually dropped in June and July, but I was able to hold onto my fitness. I posted a 35 minute HIM swim in late June, and a 70 minute swim at IMLP.
While I was initially pleased with my LP swim - and my condition coming out of the water - I exited around 800th position, which is rather lackluster. I typically make up a lot of ground on the bike and run, but I don’t want to rely on that considering that I have so much room for swim improvement. This year, two of my go-to pools are opening back up on full schedules, so my weekly volume should be up in the 10-12k.
I’m looking to knock another 5-7 minutes off my swim time. Considering my progress to date, and the prospect of an increased training load, is it likely that sheer volume will get me there, or am I likely to hit the wall? I can physically swim at my desired speed for 200-300 yds, but it’s not a sustainable effort.
I’m not a huge swimmer but I have about the same times 30-32 HIM, 65-70 IM. After having a bunch of people recommend going to Masters I finally joined this March. It has definitely improved my swim a ton. Maybe 3-5min in HIM, 5-10 in IM and I took 2:30 off a local sprint that has a 1,000M swim.
Just an example of a workout I did this morning, we did an 800, stopping for 10 seconds to check our 400 split, finished the other 400, rested for 1min then did a 400 faster than the first 400. We repeated this doing 600/300, 400/200, 200/100. I was one of the slower people in the lane so I got worked just trying to keep up. You don’t get that kind of push swimming by yourself!!
Good Luck!
I have the same issue. Are you from a swimmer background. Also I would be interested in how long you have been swimming tris.
I am not a swimmer at all, but here is what worked for me. I was around 35min the last few years and saw diminishing returns both from increased yardage and my own attempts at improving technique. Found a local coach and deconstructed my stroke, which had a number of fundamental flaws that had been reinforced by thousands of yards over the years. It was frustrating but over about 4-5 weeks I was able commit the changes to muscle memory and now swim 30-31 min with less yardage, and I exit the water without my heart at redline. So from my own experience I would say at 35min work on your form to get faster.
I’m looking to knock another 5-7 minutes off my swim time. Considering my progress to date, and the prospect of an increased training load, is it likely that sheer volume will get me there, or am I likely to hit the wall? ** I can physically swim at my desired speed for 200-300 yds, but it’s not a sustainable effort.**
Take care of the two bolded statements and you will drop the time. You have a 1:48ish 100m pace, so your stroke is probably mostly sound, you might have a few tweaks.
Every workout should have a purpose, and you should attack it hard every time. Swimming is very low impact, so you should be hitting it heavy each time. If you are swimming 3x per week, I’d be doing 2-3000 per session. One day of drills and distance, one day of intervals and one day of threshold training. Do a lot of 1-200 yard efforts at your desired pace, short rest (10-20 second). Do a lot of 1-200 yard efforts faster than your desired pace, long rest (Enough to ensure you can always meet your time goal). The first will increase the time you can spend at your top end, the second will make your top end faster.
Always have a plan when swimming. Write out your sets, give each workout a goal. I highly recommend workouts in a binder, workouts in a binder for triathletes, or many of the “fishtwitch” threads for workout ideas.
John
It isn’t really just a question of increased volume…rather what you do with that volume.
I think with any of the three sports it is very easy to just go do a workout in a brain-dead fashion. And on a run or bike you can do that and see some significant gains over time…just by building that strength up.
With swimming not only do you typically not see gains by just putting in yards, it can hurt if your stroke is poor.
I’ll assume for the moment that your stroke is okay. That may be a big assumption…but honestly a 1:10 IM swim isn’t bad. A friend I swam with in college did that at IMWI a couple years ago. That’s a respectable time.
But if you want to get faster your workouts and sets need to have a purpose. All of them. If you are looking to build speed than doing some speed work and interval training is in order. ANd it’s easy to combine that with endurance building.
Sure you want to do some 500’s and 1000’s in practice on occassion. But a great set is to do 10x100’s with 10s rest…while holding your desired race pace. That set is a staple in my workouts. (I swam in college…distance swimmer).
I see a ton of triathletes at my gym. They almost always just get in and swim. Long slow yards…just for the sake of doing them. THey get there before me and continue to swim after I am gone…and I’ll do a 55 at IMWI this year (barring any big problems) while they do 1:20+.
There are some good workout books out there. Get them and try to understand the purpose of each set they give you. Then work towards that purpose. If you’re supposed to sprint…then sprint. If you’re at IM race pace…then be there. Use a stopwatch underwater to watch your pace on longer swims.
My workouts are always organized, and rarely contain that mind-numbing long steady yardage (with the exception of the few TT workouts that I complete). But I wouldn’t go so far as to say that each workout has a goal. Usually I try to employ both short (50-100) and moderate (200-400) distances into each workout, and that is probably a limiting factor. I do recognize that when I swim short/fast distances, my stroke is very smooth and complete. When I begin to fatigue, or switch over to longer distances, I tend to shortcut my stroke - dropping my elbow and not completing my pull-through. Definitely something I’ll be working on.
I wasn’t implying that you just do mind numbing yardage, I was going off the statement that you have no formula. :wink:
Each workout should have a specific purpose, and it’s much easier to plan it ahead, rather than get there, do a warmup, think “Hrm, I’m gonna do 10x50 and rest maybe 20 seconds. Ok, that’s done. A few 100’s at race pace. Now what…”
If you know that the next workout is intervals, and your 200m pace is 1:50/100, then you can write out something like:
8x50 SKPS warmup (Swim, kick, pull, swim)
10x100 @ 1:40, maybe 1:35, 1:30 rest in between
2x200 swim, negative split each 100, pace @ 80% of race for first 100
10x50 @ :35, 1:00 min rest
4x100 build, 80% - 100% (start at 80% for first 25, build to 100%)
6x50 pull warmdown, really working on stretch and reach.
And you can get it, get it done and achieved something specific. (Total 3000 for the above workout)
John
