IMCDA - Special Needs Bags - location?
Anyone know where the bike/run special needs bags will be located? I don’t see that info in the Athletes Handbook.
I assume the halfway point for each, but want to be sure.
Thanks…
If they use the same set-up as last year, the bike special needs is just across the street from the transition area. You access it at the start of lap 2. On the run the special needs is just into the start of run. Agian very close to the TA. You should have plenty of time to walk your stuff to both spots in the morning.
Good Luck,
Gary MC
