IMAZ Transition Area map available
Looks like a draft of the Transition is posted. Although it lacks the run flow…hum.
I don’t see a “Bike Finish”. I assume it will be same as “Bike Start”–then all the way back to tents for run bags, then what? Run course says:
Exit North side of transition area and turn left (West) on Tempe Town Lake South Shore Bike path.
Pass under the Railroad tracks
Left on Path to Rio Salado
Right on Rio Salado
North is to the right on the T-map, so I don’t get it–fortunately I will have lots of people to follow!
Yea, your right, but you gotta assume Bike start = Bike Finish. I figure the Run start overlaps where the Swim Finish is and then when you come around for the second lap of the run, it looks like they’ve got you almost running through the special needs area, which doesn’t make sense, considering folks will be coming off the Bike as runners are on their second lap.
What’ even more confusing is how are they gonna track which lap of the Bike are you on? And when should you break-off on the “Tempe City Loop”. You gotta figure they’ve have arm bands or something for each lap??? Anyone got an insight.
What is the bike neighborhood like–should the need arise, are there some bushes around that may need watering?
beeline / McDowell / Alma School nad McKelleps are all clear for the taking. The run course has many bathrooms on the route as well as secluded areas that may need watering.
JIC you were wondering the bike racks are on the grass. Sloping a little toward the lake but not a concern, unless they forget to turn off the sprinklers :slight_smile:
Watering no problem…fertilizing may be an issue…as one of great friends from Asia refers to himself: “It’s like a tree in the middle of the desert”
As someone else posted, the run start will be almost exactly where the swim finish/ramp is noted on the map. You will head west, next to the lake, for 100 yds or so, then turn left on a path over to Rio Salado, where you will turn right (west again) to turn around in about 1 mile. Then, you come right back through this area again, along the lake for another mile or so east of the transition area. The run special needs area appears to be located just east of the T area, so we might hit it at mile 15 or so. Is that where it usually is???
