Again, thanks…I see the basic concept here. What I/we actually deciede to do for a plan , ie: distance/time/intensity is variable depending on the athlete. I know my limitations and I know when to " back off" a bit. I will formulate a training plan starting with a solid base, mix in a little intensity here in there to stay “sharp”. On the build segments I will increase both slowly and always see how I’m feeling. Ill do a few races before my A" race, one 1/2 about 1.5 months before, then some long, hard bricks to get used to the long distances and get dialed in with nutrition. A few weeks out start a taper and then will see how it goes…
Though I do agree that everything is absorbed in some way, I still think you can accumulate junk miles. In fact, I would say if you listen to what your mind tells you to do, you will very likely accumulate junk miles. While training for the 70.3 doing 3-4k repeats at 3:25/km feels much more comfortable than at 3:08-3:10/km. But, I can run at 3:25/km all day, and would love to, but this it is not going to do much to help me run 3:15/km off the bike. Thus, while training for a 70.3, I would say the time spent at this pace is junk. It’s unnecessarily taxing to be chalked up as working on Endurance adaptations, and not taxing enough to be working the Lactate Threshold and Vo2Max to an adequate degree. On the other hand, if I was training for ultra running events, intervals at this pace would have a lot more value.
With regards to Ironman training, I think the tendency is to listen to the mind. The logic goes something like, “I race much slower than pace X, so I don’t have to train at pace X any longer, instead I’ll train at pace Y, which is slower and puts less taxation on my body and mind.” I believe Dave Scott in a fairly recent interview said that the reason athletes aren’t much faster today than he was in '89 is because they take Ironman training as a “license to go slow.” The upper limits drop over time as they are worked less and less. The spread between race pace and the upper limits becomes less. It is likely that very little improvement is seen over time, and it is quite possible that performance actually decreases from season to season as the spread between race pace and upper limit becomes progressively less.
Everyone is different in this regard. I’m sure you can find examples of people who have trained for 30 hours per week and did an 11 hour Ironman, and people who have trained for 10 hours and did the same.
Or, those freaks that can do 11 hour Ironmans on 5 hours of training, maybe on none? You should test this.
Didn’t Ben try this ![]()
Thanks for the details…I see what your doing and can apply that to what I need to do ( adjust pace to my current fitness level etc…). I want to be well rounded and feel I was way under prepared for my first 1/2 last year. Was only biking 60-80 miles a week and as I mentioned, only running 15 a week. My half was ok I guess, but I stunk up the run. First three miles at 6:50-7:00 pace and then got a thigh cramp. Up to that point I felt great!. Was not winded but the leg just cramped up. Was eating and drinking well, taking in electrolytes and I just attributed the cramp to lack of training. That half was my longest bike and run that season so I believed that to be the cause. Dont feel I over biked at 24.8 MPH either. I was holding 265-270 watts which felt fine. Anyway, I need to put the miles in to get to where I want to be, Thanks again and good luck on your season LSanders!
Cramping, I believe is Never, ever electrolyte related. You body just sweats out the excess you consume anyway. The risk is being severely low…or essentially drinking too much. You nervous system can’t function right and your heart stops. Other minerals can impact metabolic output and muscle firing, but there’s never been a clear link to cramping. It would be more systemic and more gradual. Cramping is neuromuscular. If your severely dehydrated, you don’t cramp either, you blood gets thicker and at some point blood flow starts to suffer and you start losing brain function and fall over or pass out… or overheat from lack of cooling. GI issues are also more often than not, linked more to intensity, than fueling.
You cramped because you lacked the specific fitness to sustain that intensity. You need to bike and run more. Don’t over complicate it.
BTW - since you posted it… how tall are you? 24.8mph is great, but seems on the lower end for 265-270 Watts unless it was a very hilly course or your fairly tall. You might want to keep refining your position and equipment. Could be some low hanging fruit there too.
Im 6’1" and 175 lbs. It was a fairly hilly course at 2500+ feet of elevation gain for the 56 miles. I was a little uncomfortable with the seat I had as well with my hands on the bullhorns for a good 5 -7 miles. Ive since got a new adamo seat which is much better. I think I was in a bit of an agressive position as I had the bike set up for short sprints. I will address that soon as well.
