IM Moo bike selection..what would you ride?
Hi all,
I have been struggling to determine what bike for ride for IM Moo. I have been training on a road bike w/clipons all winter. I also have a TT bike (Cervelo). I planned to race on the road w/clipons but am wondering if this is a mistake…the aerobars, setup on the TT is better for the flat sections of IM Moo. What do you think? The road bike is lighter thanthe TT bike.
KK
TT bike.
I have done IMMoo 3 times. I live close, so, I have ridden the course dozens of times.
TT bike. No question.
It is a hilly and technical course, but, you can make big gains in several sections on a TT bike.
Road bike with shorties. More comfortable. Better handling. Those that argue that a TT bike gives you so much aerodynamic advantage, eh, I think it’s mostly in the head minus a few minutes…
IM WI has a lot of turns. Short ups and downs. You know, unless you’re a pro, it doesn’t matter…
Im not even putting the shorties on my road bike. I don’t think I’ll lose a hell of a lot of time 'cause I’m not going to be hammering either way, and I’d rather sit on my sit bones then my junk.
You know there are saddles that address that, right?
To the OP- I did it w/ clip-ons in '07. Wish it had been TT setup.
Unless you are a really strong cyclist, go against the grain and use your road bike. There are more grades at IMWI than there are flat roads. I used my road bike at IMWI 2007 (without clip ons) and while I admit I was one of the few out there on a road bike, I passed craploads of people on every hill on my way to a 112 mile PR. Didn’t regret the decision for a minute.
Can you ride your tri bike in the aero position? Can you do it for your long rides? If so, ride your tri bike. Moo is a tri bike course all the way. If you can’t ride your tri bike for some other reason (physical, comfort) that’s another issue, but the fastest bike on that course is a tri bike. No question about that.
Tri bike – likely with a compact crank (likely) and 12 x 27 (probably a requirement) to allow for easy climbing.
I will be doing IMMoo for the first time this year and have not yet seen the course. Please define “technical”. Are you using your breaks for many, many turns? Or just a couple? Are there 90 degree turns where a good bike handler could carry the 20 mph speed through without breaks?
Thanks for your thoughts.
David
Either one will do fine! Go with what you are comfortable on. I will probably go with a Cervelo S1 with clip-ons.
David
Most turns are sweeping enough that a good bike handler would be able to make them no problem, however there’s a couple sharp turns, 2 specifically that I can think of. The first is on a downhill so breaks are necessary, the second is at the bottom of a hill with a big ditch right behind it… just make sure you slow down if you see people telling you to slow down for a corner.
I’m going to be on a road with clip-ons, but if I had a TT bike I would be on it instead.
Now I’m off to find a thread about which wheels to run (so I don’t hijack your thread)! It’s fairly hilly (I was raised in Utah, people around here sh*t their pants about how ‘hilly’ the course is but I’m use to riding in real mountains) and some people are afraid that a deeper wheel is going to be tougher to do the climbing with. I’m renting wheels and this will be my first time on anything better than the stock aksium wheels that came on my bike, so I’m pretty stoked about testing some different ones out. You might want to think about wheel selection too.
David
A big piece of this equation is how strong of a swimmer you are (stay with me here). I’m a garbage swimmer, was worse back then, and got elbowed in the nose pretty good, adding 10 min to my already slow swim. I passed about 900 people on the bike; there are places you could corner w/out brakes, but there are lots of folks clogging the way, so you need some brake to stay out of trouble.
If you are a decent IM swimmer (I’m figuring 1:10- faster folks can give you the skinny), and don’t jack around in transition (T1 at Wisconsin can be long), you’ll be on a MUCH less congested bike course until the 2nd loop.
TT bike all the way. There are plenty of flat and false flat sections where a TT bike is superior to a road set-up with clip-ons. I’ve ridden that course a ton over the past 6 or 8 years, and a TT bike THAT YOU CAN STILL REASONABLY CLIMB ON will be faster than a road bike. Remember to include your low climbing gears - the hills are not too long, but they are numerous and rather steep.
What are your goals? Are you looking to go to Kona? Are you looking for a new PR? If every second doesn’t count - ride the bike that you want! Who cares about a few extra minutes on the bike if you are not comfortable and happy.
That being said, you should as comfortable on your TT as you are on your road bike.
I think a tri-bike with 12-27 is a contradiction.
Axel
“I think a tri-bike with 12-27 is a contradiction.”
Why do you think this? Seems to be a great set up for IMWI. After doing the race 3x with a 53/39 and 12/23 on the back this is exactly the way I would go in the future. I ride in my aero bars 99 percent of the way and ride a very FOP bike split followed by a solid run. Compact cranks and a 12/27 provide more than enough gearing for just about everyone.
You rode 99% of the Moo bike leg in aero position?
Axel
Yep, maybe a little more…maybe a little less. I am never out of my aero bars. I even ride in my aero bars up the “big hills”. Benefits of a well fit bike and a good level of comfort from lots and lots of riding in the aero position.
Wow. I am 100% certain that that makes (timewise) no sense at all.
Axel
