I'm Freezing
Today was a beautiful fall day in south eastern Canada. 6 degrees Celcius/43 Deg. F. I pulled on my tights, socks, booties, cool max sleeveless T, cool max long sleeve T, polar fleece top, short sleeve jersey, coolmax beanie, helmet and my gloves. I was probably wearing 5 lbs of clothes and the wind was still whistling thru my chest hairs. (both of them…)
I hate wearing $500 worth of clothes and having to jam a grocery bag down the front of my jersey to stop the wind. I tried a running jacket and it flapped in the breeze like mad. I’d prefer some sort of wind resistant underlayer since I don’t want to wear anything over the jersey.
What is the magic piece of clothing that I’m missing? (Yeah, yeah, the Canadian guy’s asking what to wear in the cold…)
Brad
Fleece alone won’t stop the wind…it goes right through it. Get a cycling jacket or a soft shell jacket. I ride all the way down to about 35 degrees with a decent cycling jacket. I’ve got a Castelli that works pretty well…check this out from Colorado Cyclist:
http://www.coloradocyclist.com/common/products/productdisplay2_v2.cfm?PRRFNBR=37531&CGRFNBR=407&CRPCGNBR=407&CI=1,259,407&TextMode=0
Spot
Dump the polar fleece and wear a good winter cycling jacket. It’ll be more form-fitting than a running jacket and won’t flop around. You need something windproof as your outermost layer. Control your body temperature by zipping it up or down. Don’t get overheated and sweat too much during the first hour; you’ll just get chilled. Also, your tights should be winter ones; not lycra. Hope this helps!
Craft makes a t-shirt ( Lager Layer 1 ) that has a solid, nopn breathable wind covering on the front of the t-shirt and the rest of the shirt is a ribbed polyester. A must for cool/cold weather riding…
The wind is wisking away your insulated layers of warmth. You’ve got to get a windproof layer. Odds are tough on finding something to stop the wind for the inside, so you might want to check on a nice semi-snug outer layer. Most bicycle shops will have a jacket/“windbreaker” that will not flap too much in the wind, but will keep the warmth in.
I personally use a crappy Old Navy rain shell, over a short sleeved bike jersey, and long insulated bike jersey. No fleece or any other layers. And that works well down to 27F here in Portland, unless it is raining cats and dogs. In fact it is usually too warm for anything over 40F.
Good luck.
Here are your 2 options.
Both of these were designed for Mountaineering but I’ve seen motorcyclists use them in the winter…
the fabric is Gore Windstopper N2S
http://www.mountainhardwear.com/images/productImages/OM1547-010x.jpg
Info: http://www.mountainhardwear.com/Product.aspx?top=1&prod=1477&cat=25&viewAll=False
or
http://www.patagonia.com/web/us/product/collection.jsp?OPTION=COLLECTIONS_DISPLAY_HANDLER&pageSize=11&pageNumber=all&ws=&catcode=MAIN.CLOTHING_GEAR.MENS.SHIRTS#
Info: http://www.patagonia.com/web/us/product/collection.jsp?OPTION=COLLECTIONS_DISPLAY_HANDLER&pageSize=11&pageNumber=all&ws=&catcode=MAIN.CLOTHING_GEAR.MENS.SHIRTS#yc
If you have to wear that much at 43 F, what do you wear when it is really cold. I live in SC and still wearing shorts at 32 F. Get a good wind layer that fits close to the body and that is longer in back to keep you rear warmer. The plain poly layers will not stop the wind. I have several vests of various thickness that stop the wind. Gortex, nylon, or other wind stop fabrics usually work well.
It was 70 F in Charleston, SC. I was running in shorts and sports bra.
I’m cursed with 9% BF. I wear a sweatshirt year round except for July and the first 3 weeks of August. Maybe I’ll should try the bra (or in my case a “bro”)
Brad
Hey, I live in Mt. Pleasant, I was sweating rocks this a.m. for 10k. around Park West, very humid. I was in shorts and a tech-t, but um, no bra, I only wear that on Saturday nights.
I know they make gortex or some type of wind stopper underwear to keep the lower part warm. What do you wear on your feet?
  • “I’m cursed with 9% BF”*
    If you go from 9+ hours a week to 4 or 5 hours of training a week for 8 weeks and eat the same, you will gain weight fast. I looked like Mrs. Porky running a 5k race today. But I can say, my time of 21:19 (which is a horrible time for me) is my best time of the year.
Off I’m Freezing… topic!
Imatoad - Since you are from Mt. Pleasant, do you know of any swim coaches in the area? I live in Summerville and work on East Bay and usually swim at MLK, but can swim at MUSC. I can’t swim masters with my work schedule.
I love the UnderArmour winterweight mock T - even at a windy 10F, I wear it as a base with only a T-shirt and a long-sleeved T over it (both of the outer layers are technical fibers, of course - and good gloves and hat help) for a run of up to 1.5 hours. The cycling jacket is mighty handy if it gets really cold, but down to moderately cold levels, as long as the wind isn’t too nasty, I tend to avoid outer layers that are too heavy.
I just use a basic outer shell like this one from REI
Layer up underneath it to match the weather for the day. Nice thing about one like this one is it has the longer tail so it covers your lower back when hunched over. The one I have is really thin material, so it doubles as a rain shell in the summer – roll it up and stuff it in a jersey pocket.
Thanks
• Jeff
You need cycling specific clothing. I went out in a light drizzle today, with moderate to gusty winds and a temp of around 5deg. On top of my bibs I was wearing a merino short sleeve jersey, arm warmers, and a lightweight Sugoi jacket (much thinner than the standard fall/winter jacket, but still having windblock panels in the front and shoulders). Over my shorts I had a midweight pair of PI tights, and plastic baggies over my shoes and under my booties. Most people will wear a thin base layer underneath, and if I could find my rain jacket I’d have worn that as well. No skullcap, although I did entertain thoughts of wearing a shower cap over my helmet. The only part of me that was cold during the 2hr ride was my hands, and only after my gloves soaked through. I have yet to find a pair of gloves that still keeps my hands warm once they’ve become saturated with water.
Look to Sugoi, Perl Izumi, Castelli, Craft, or any other company that makes cycling specific clothing. Running clothes generally won’t be cut closely enough, and will flap around. Also, good cycling tights will have windblock panels in the front.
The do make Gore-Tex socks, but most cyclists wear plastic baggies over their shoes and under their booties. If you don’t have booties, get some.
Pearl Izumi Gavia Jacket!!
I don’t know of any, but I’m sure there are plenty in the area. If you ever get to Towne Centre in Mt. Pleasant there’s a very good tri specific store called TrySports there and they will definitely be able to give you some names. Here is their number: 843-849-9292
http://www.trysports.com/
Khai, get a pair of those 5mm neoprene paddlers gloves that Simon got from MEC last year. I got a pair then for less than $20 and they are superb. They keep my hands warm last winter in Van and that includes the day we were out for three hours in the wind and rain and even when he stopped with a puncture. As for your feet the Sugoi overshoes that have the smooth skin on them work very well and merino wool socks stop you from getting cold feet.
This probably sounds counterintuative but, you might be wearing too much clothing. If you are doing aerobic excercise, you are likely perspiring and drenching your clothes. Because liquid is much denser than air, the cold sweat you are likely stewing in will drastically impact your body temp.
I am a backcountry skier and have been in some severe winter conditions including high speed winds. However, I never wear more than a nice wicking underlayer made of 100% poly and a winter shell with pit zips. I do bring along extra layers of clothing but only put them on if I’m dry and idle.
As some have mentioned, look at your outdoor clothing brands – Arc’teryx, Patagonia, Marmot, Mountain Hardware, Mammut, Cloudveil, etc. – if you want something that is highly wind resistant. Personally, I wear an Arc’teryx Beta AR shell. I will use this jacket running on extremely cold days and I’ve never had a problem with it flapping. I have NEVER felt the wind while wearing this jacket it breathes just enough to keep me warm and dry. Again, avoid anything that is insulated. You’ll be suprised at how warm you’ll stay with just a shell and nice poly underlayer.
http://www.arcteryx.com/images/popups/Beta-AR-Jacket-Mandarin.jpg
I’ve had great luck with MEC’s softshell gloves.
http://www.mec.ca/Products/product_detail.jsp?PRODUCT<>prd_id=845524442619439&FOLDER<>folder_id=2534374302539665&bmUID=1167765374042
I just wring them out once in a while and they stay really warm when wet.
Too cold for that and it’s fleece mitts with Gore-Tex overmitts :slight_smile:
I tried the paddling gloves and they were lovely and toasty but it hurt my hands to grip the bars for long periods of time with them on.
