Has to open up easily and not have the straps pull through the loops when it does.
NO RIDGES ON THE INSIDE TOP OF THE SHOE! So whatever tongue will have to be completely internal (like the Sidi Lazers). The Sidi T1 tongueless design is good too.
Easy, a boa lacing system (a la specialized s-works), mounted at the rear of the shoe, just below the finger loop.
Carbon sole,
Plenty of venting on the front of the shoe, and microfleece inside, so you dont have to vaseline the tongue.
3 bolt compatible only. The nike t-speed has holes for every mounting system, and if you are using look,time, etc, the plate for spd’s clicks everytime you pedal.
