If I want to build my own wheels
I know we’ve talked about wheelbuilding in the past, with some calling it outdated and others calling it art.
Lets put that aside for the moment.
If I want to build my own wheels, do I dare start with good stuff like Record hubs and Open Pro rims, or should I do a trial run with cheapo components first?
You won’t wreck the rims or the hubs on your build. Pretty much the worst you can do is messing up the lacing. It doesn’t damage anything, it just pisses you off a bit. So, if you want a nice set of handbuilt wheels, go for full deal. I do recommend picking up the Zinn book on road bike maintenance. It provides a great guide for building standard 3x wheels. A good truing stand and a decent spoke wrench also makes it much more pleasurable.
After that enjoy the build.
If this is your first time building the wheels, it might be a good idea to have someone who knows what they are doing (your local shop) give the wheels a once over before you take them out for a ride (just in case you did mess up).
I’d start with a book like Zinn and the art of road bike maintenance or one of the more specialized wheelbuilding books. I think rims and hubs can be reused if you don’t trash them but spokes should be new each time. Talk to your lbs to figure out what components would suit your riding style and weight best. Note: I am too chicken to try building them myself.
I had a Mavic Open Pro with my PT hub crack on me so I ordered a Velocity Deep V rim and spokes from wheelbuilder.com (great guys to order from btw) and built up my first ever wheel with a Powertap hub. Had it all perfect and took it to the local shop just to check the tension, which they said was too low using a spoke tension tool. Tightened it up as needed and I now have a solid wheel.
When talking to the wheelbuilder guy, I was telling him I was having difficulties keeping the Open Pro true. He said the Velocity rims were strong and solid. Rim and 32 spokes came in around $85 or so.
It would be good if you could rebuild a wheel on an old bike for practice… But definitely get a spoke tension meter, it can be hard when your starting to gauge the proper tension without one. I’ve only built 3 wheels so I’m still at the starting stages.
I see no reason to not use a Record hub…and would use a Mavic rim (with eyelets). I would also use “spoke prep” and tensiometer. I would not use a PT hub however. I build a nice wheel today - I feel kinda sorry for the folks who got the first ten I built, and not great until I was at about 70+ wheels that they were bomb proof wheels.
I have built over 10,000 wheels, and I think they come out pretty good now that I’ve had some practice. BUT - I started right where you are. You are not going to wreck the hub, and it is unlikely that you will do anything bad enough to the rim that you cannot redo it if you want to. Read some articles, go slow, keep your spoke tension even.
Have fun, Andy (I work at Hed)
First ever wheels I built (many years ago) were Ultegra hubs and Open 4CD rims (the great-grandfather to the open pro). I say go for it.
Jobst Brandt’s book is a good one. There are good lacing instructions you can find online as well (along with spoke length calculators).
sheldonbrown.com
got all the info for the wheel building thing.
it’s free free free
have fun and nice wheels to
Dirt
There is something wonderfully satisfying of riding wheel’s that you built. Get Joe Brandt’s book, set aside an afternoon, and have fun! Starting with a front wheel (even dish), a rim with eyelets, and a 3x pattern will be the easiest and most resilient to your errors. Unless you are over 185, 15g spokes will be just fine. Brass nipples. And have the shop put a little spoke prep on the threads for you.
Although a tensionometer is very helpful, when I learned at the bike shop 20 years ago, the owner taught me to check tension by pinging the spokes. If they all ping the same tone, they have the same tension. I still use my first front wheel for cyclocross every now and then.
Do borrow a wheel truing stand from someone. I couldn’t imagine doing it without.
good advice so far on this topic. the only thing i can recommend is buying a 6-pack of beer. it helped calm me down during my first wheel build.
what they all said. I built up a rear wheel for my fixed gear using a crazy lacing pattern. I practiced on the origional wheel from the bike (bought the bike for the frame). It really wasn’t needed. It was nice to have the practice tensioning and turing, but I could have gone without it.
Just a hint, it’s a pain in the ass to get good tension and true without a truing stand. The ‘between the brakes’ method works, but it adds a lot of time. I’d get it as close as possible, flex it a bunch, ride it off some curbs then take it in to your shop for final truing.
Another vote for the Brandt book. He has a tendency to preach but the material is quite good. Consider starting with the Zinn book if you just want to quick and dirty method for building a 3 cross wheel.
Also…
stick with standard 3 cross for your first build
try to spec brass nipples as you will likely bugger up alloy nipples if you are not careful
make sure you verify and reverify spoke length with whatever rim/hub combo you use.
use double butted spokes 14-15-14 (avoid the DT revo’s and straight gauge spokes for now…)
use grease on threads if you don’t have spoke prep (I don’t bother with spoke prep since grease does a fine job)
get a good spoke wrench, avoid using the “multi sized” ones as they are likely not to fit as well
  • if you have the money, start with good stuff (e.g., Mavic OP, Velocity Aerohead, good hubs and DT/sapim spokes). it will reduce the frustration of trying to true a wheel that is of poor quality
  • Edited the book author name
