Ben, I used to do single leg pedalling exercises, but, I could never do them for long, nor at “normal” rpms, and I would get bored after 15-20 minutes of attempting it anyway. But, I did do it in the offseason or when on a trainer. It just wasn’t even close to PC riding, at least the way I was doing it.
I continue to train most of the time on PC’s. You have to realize, thats almost always less than 100 miles in a week. Usually, I only get to ride 50-75 a week. 68 miles is my furthest PC ride, although, I may break that later today…I have the day off. If it wipes me out, though, I’ll cut it shorter, I’m still recovering from a race I did Sunday, and I have another this Saturday. I know running doesn’t interest you, but, that’s another benefit of PC training…I won’t have to run this week…maybe just once for a couple of fast miles (relatively speaking), and that’s it…no worrying about losing running form when I do a good PC ride that week. On Friday, I’ll get out my TT bike and ride 10-20 miles mostly easy with a few hard pushes, and the whole time try to concentrate on imitating my PC stroke as much as I can.
Since I cannot stay in the aero position on PC’s, and most of my races have long sections of flat ground, I don’t trust myself to be able to keep up top speed, so I haven’t raced on my PC’s…However, I should have in the first race I did this year…it’s a brand new race, it was only 9 miles, and it had essentially NO flats…it would have been perfect for me and PC riding as I am always faster on PC’s uphill.
For someone with relatively little time to train each week, I don’t think I’ve come close to reaching the potential PC-type pedalling can offer…especially since I can’t maintain real good aero positioning for long sections. I think that position is possible with further PC training. On the other hand, on a hilly Ironman course, like Duke Blue Devil, I have no doubt I could PC that course just fine, because I’d be in a much more upright position for neck comfort anyway on such a long ride.
The thing is, on regular cranks, as long as you are PC pedalling, you should be just as efficient. The problem is determining if you are PC pedalling on regular cranks…there’s no feedback to tell you if you are, indeed, lifting enough. On PC’s there is no question if you missed picking up during a stroke.
I think it is a little like golf…if you’ve had a swing that usually results in a slice, but you learn to swing correctly from the inside out by using a device that requires you to tuck your elbow in just before impact so that you hit it straight, or even hit a slight draw, you have to practice that new stroke thousands of times to imprint it over your old slice swing. When you remove the device that requires you to bring that elbow in at the right time, but were blindfolded so you couldn’t see the results of your shot, you wouldn’t really know if the ball flight was correct or not…so, did you tuck your arm too tight…causing a hook, let it fly a little so the ball faded, etc.?
It’s not always apparent on regular cranks when you start to fail at the PC stroke, and when I’m fresh, I may actually be pulling up more than I need to on regular cranks…resulting in a premature fatiguing of my minimally adapted PC muscles…so I’ll be failing in performing my PC stroke sooner than usual. When I’m tired, I may think I’m getting a good PC stroke on regular cranks, but, I don’t really know unless I think about it enough to feel my foot lifting in my shoe a bit.
I think RotorCranks will provide better downstroke efficiency. I’ve been mostly training my upstroke efficiency with PC’s. I think the effects of both will be additive, as long as I can unweight the rising pedal of the Rotors…since the rising pedal will be moving slightly faster than the downstroke crank, it will be a challenge, but, all I have to do is to unweight it more than I could pre-PC training, and I should be even faster on Rotors than if I had not had PC training.
We’ll see!
