Ideal Altitude Training: Just sleeping, or interval stuff, too?
With an altitude training device that you can use as a tent or a mask, I imagine the easiest way to take advantage of it is by sleeping in it. You can get a blood test done and (I suspect) see a change in your RBC count. You can then follow the live high - train low meme that is becoming popular.
However, I understand that some peole, including Andrew Coggan, do interval training at altitude. I presume you could do indoor trainer work (or treadmill running) with the face mask. I’m not sure how the physiology here give you a benefit.
Doesn’t training at altitude limit how hard you can push your body? Isn’t it more ideal to train in a hyperoxygenated environment so you can push your body harder in training?
Yes I have read that the sleeping at altitude is best rather than training at altitude. Unless perhaps you have a race at altitude, then, you’d want your body to know how to function perfectly at that high altitude environment.
A 24hr fitness in Eugene Or used to have an altitude chamber (not sure if they still do) that they had one treadmill and one bike inside of. It was pretty cool to train in there, but it was damn hard.
Coggan does it, so there must be some reason he thinks it’s the bomb.
I’ve only used hypoxic training when preparing for competition at altitude (which is the only time it really makes sense).
