I up graded my old road bike to Ultegra but I cant get it to shift right
It has down tube shifters. To save money I decided to stick with down tube shifters.These are the ones I got from Nashbar.
http://www.nashbar.com/profile.cfm?category=104&subcategory=1194&brand=&sku=3042&storetype=&estoreid=&pagename=
The bike shifts fine 1-8 and it will go into 9th but the chain keeps jumping up and down.I had a friend look at it.He says it’s my down tube shifters.Something about when Shimano changed to STI back in the 90’s from then on down tube shifters wont work with anything made after that.This doesnt sound right to me. Shimano’s instructions dont say anything about this.Can anyone help me out here?
Dave
First you need to set your stops on your new R/D. You should be able to download instructions from Shimano if you don’t have yours anymore. This will set the limits to how far the R/D will move at both extremes. I find that this is easiest to do without the chain installed, but is not mandatory. Next, shift your F/D such that your’e in the big ring and shift the R/D such that you’re in the smallest diameter cog, all the way to the right. Now up shift once. If the chain doesn’t move increase the tension until it does. Once you’re in this position, continue to increase the R/D tension until you begin to hear noise from the chain running into the third gear up. When you hear the noise, back of the tension just a tiny bit. That should get you pretty close. Try the gears, and you may have to tweak the tension a 1/4 or 1/8 turn depending on how it runs. You’re new cables will stretch some as they become used, so a re-adjustment will likely be necessary after a couple rides. I’m not a mechanic, but I build and maintain my own bikes, and this always works for me. Though I still have to refer to the Shimano prints to determine which screw to turn and in which direction when setting the stops:)
You know my reply…
did you switch the derailleur or just the shifters?
See that’s my problem. I did that. It still wouldnt shift right, I tryed everything I could think of and nothing worked. So that’s why I ask my friend for help. So I guess what I’m asking is, will down tube shifters work with a new Ultegra 9 speed R/D?
Thanks Dave
All new drive train. All Ultegra but the shifters which are Dura-ace.
Ya I do. You have any spare parts lying around? Id be glad to put them on my bike.:wink:
Dave
Dave,
I’ve never used down tube shifters. If they are anthing like bar end shifters, then there might be something else to try. I once put together a 9spd set of bar end shifters and incorrectly placed the keyed disk that goes between the shifter and the shifter mounting base. Since I aligned the key wrong, I could only get part of the gear range, not all of it. Don’t know if down tubers are built that way, but if they are, try rotating the disk to a different position. Bottom line appears to be that there is too much tension in the R/D cable and it won’t allow the R/D to seat properly in its most “relaxed” position (i.e. least tension on R/D or smallest cog).
I am currently using Ultegra R/D with Dura Ace down tube shifters without any trouble. In fact, the Nashbar page you referenced is exactly where I got mine shifters. No troubles at all with the operation either on the trainer or under load going up hill at the Horribly Hilly Hundreds in Wisconsin this summer. I don’t know what to tell you for trouble shooting but I do know that the combination works. About a year ago I upgraded from an old 600 Ultegra rear 7 speed to a new Ultegra rear 9 speed and Dura Ace shifters. Maybe loosen all screws and stops, release the cable tension and start from scratch. All I did was put the chain on the big ring and slack the cable. Adjust lower stop until the chain rides quietly in the small cog. Take slack out of cable and tweak cble is necessary to maintain position on small cog. Shifted like a champ from the start, after I made sure the upper stop was set so I didn’t toss the chain into the spokes. 1990 vintage Cannandale 3.0 series frame.
ars
**Astewart thanks that’s what I wanted to hear. **
Dave
