We can’t see your pics!
And what’s the “noodle?”
Bent hangers can be straightened… broken ones get sent to Trek.
Depends on how bent - either way it would be weakened. A non-replaceable der. hanger became the excuse for not buying Scott CR1’s a year ago. I see this as a big mistake. Bent & broken hangers are all too common, and you shouldn’t be forced to be without your bike for what is otherwise an easy fix.
The trek derailleur hangers are pretty strong.
We added the noodle to help the cable routing for the rear brake. Some riders did not like the cable sticking out slightly to the side. The noodle helps keep the cable tucked up to the frame. I have not had any issues with the cable rubbing my leg without the noodle. That bike weight is right around what I have as well.
I’ve got nothing against trek and other manufacturers do the same thing, but you got to love Treks marketing. The first OCLV frame was quite some time ago. Since then they have had maybe 6-8 new generations. Every new generation they claim the frame is lighter. By now the frame should be lighter than air.
Styrrell
What kind of adjustment range do you get with the seatmast? Is it one of those where you cut to fit, then you have 15-20mm of play?
No cutting on the seatmast. The extension attaches to the saddle and overlaps the mast by a bit. There is a pretty good amount of adjustment and if you need more for long legs you can get a longer extension. You can also get different offsets.
I do not have my bike in front of me, but I think it is around 100mm of adjustment with each seat cap. I will measure when I get back to the office. There will be two more lengths available in the near future, both longer than the current production piece. No cutting! With regards to the 8 different versions of the OCLV frame and each “supposedly” getting lighter… I can confirm that the last three frames have each gotten lighter. While I do not have the stiffness info, I do have the weights, and they have gone down. I was fortunate enough to work with the original Madone, the Madone SL (both 110GSM and 55gsm) and now the Madone Black, Red and White. This new frame is the lightest yet. I need to weigh the new production Lemond Tete frame and see which is lighter… That bike, production 57cm frame, came in under 15lbs. It will be interesting to see what the 6.9 will weigh with production parts, should have no problem beating 15lbs…
Styrell,
I agree that it is pretty funny about every generation being lighter should make it lighter than air, but that is marketing. Save one (1) gram compared to last year? Hey! This bike is lighter!!
The interesting approach Trek has taken (in my biased opinion) is focusing on the fuselage (incl. fork and seatmast) and not just on the basic frame. People who really like to swap out all of their parts for their favorite brand (Thompson seatpost? Reynolds fork?) can’t do that on these bikes, so they might not like it, but look how many companies are coming out with masts (Look, Giant, Scott, Trek) instead of seatposts and have odd sized steer tubes (Cannondale, Ridley). If this trend continues then smaller manufacturers that depend on seatpost and fork aftermarket sales could see a big drop in sales.
True, there are some parts you cannot replace with aftermarket (yet) but I think that if said consumer rides the bike they will see that there is no need to replace the parts in question. An integrated seatmast not only makes the frame stiffer but is more structurally sound. There is much less chance of failure of any kind.
Some more thoughts on this bike after a day of working on it and riding it.
15.89lbs/7.22kilos For a complete Madone 5.2 Performance, 54cm, no pedals. Pretty good for an Ultegra bike with mid level wheels!
Seatmast is a clever design. NO CUTTING!! That is great! While I still think the Look 595 is the pinacle of road bike design, I have to admit that cutting the seat mast (which I have done more than once now…) is scary at best! Nothing quite like taking a hacksaw to a $3800 frame and praying that you got all of the measurements right!! No, instead, the Trek design slides over and clamps onto the integrated mast. One drawback that I saw. As someone mentioned earlier, there is only one size mast available at this time (more to follow soon) which means you only have a limited amount of adjustment… I think it was in the 100mm range. Not bad, but in my case I wouldn’t fit on my usual frame size… I usually ride a 54cm, but with the mast in it’s highest position my saddle height was still 2cm too low! That bumps me up to a 56cm, but I don’t care for the fit as I feel the top tube is a little long for me. Hopefully different length caps are available soon.
The bike is very responsive! As I said earlier, it rides like a much lighter bike and feels like it wants to jump at every pedal stroke. This bike begs to be ridden faster! Again, the only bike that I have ridden that feels better overall is the Look 595… and yes, that includes the Soloist Carbon and R3 (although I am quite fond of both of those bikes.) The Madone feels like a more complete bike. The bike continues to have that Trek carbon “comfort,” but without feeling “dead.” As mentioned earlier, the tubes are HUGE. In fact, I found that I was banging my knees and thighs on the toptube quite a bit… New integrated BB (bearing kits are available for various manufacturers cranksets) and huge BB junction mean that this bike is very solid. No descernable flex from BB are at all. It feels as if this bike accelerates just from you thinking about going faster! Only bad thing about new BB shell is no 9 speed invited to the party! Let’s face it, if you are thinking about this frame and have 9 speed… well, it’s time to upgrade anyway!
Frame is still made in the US. I assume Trek will still offer to repair/replace it’s carbon frames if damaged. Non-replacable hanger is an interesting decision… maybe any Trek employees/designers on ST can fill us in here… It does look nice and beefy, but if I’m buying this frame, I don’t want to tear it down and send it to Wisconsin to have it repaired! I still have not seen any specs on geometry. What we have are 5.2 Performance, which have a 30mm taller headtube for a more upright, relaxed position. They come stocked with a 10mm shorter stem than the Pro, which is aimed at being a more “race” bike (although I thought the Performance felt pretty racey as well.) The only thing I found a little odd was that the 54cm I rode had a 53.7cm toptube! Used to be in the 54.5cm range…
Overall, I think Trek got it right with this one. I have to admit, I was not a fan of their road bikes before. They have always been superbly made, and Trek does a great job of standing behind their products, but I have never really liked the way they rode. Always seemed a little too dead. These are MUCH more lively!
New Bontrager RaceLite hub. Lots of milling to shed grams!
New Bontrager XLite stem. 4bolt clamp. Much more svelte. Notice how wide new toptube is.
Handbuilt in the USA. Notice all the mill work on the new Ultegra SL chainrings.
Huge downtube and BB juncture. Ancient (circa 1995) Lanzera indoor soccer shoes sitting on our new shop hardwood floors in the background.
Still my most comfortable shoes!
NO CUTTING!! My favorite part. Flat, thin seatstay yoke, a la LeMond carbon. Again, the wide toptube.
I am not sure when the first pro models will go out the door. Currently the 5.2 and 5.5 performance should be on shop floors…
Aftermarket fork sales have taken a nose dive in the past 5 years, so I doubt that this will have much effect. Most bikes are coming with nice forks stock now, so a lot of the companies that once relied on aftermarket are now going after OE sales. I think in the long run they will do better that way…
I don’t think any company out there really DEPENDS on aftermarket seatpost sales… maybe Thompson, but I can’t see their popularity going away any time soon.
There is a good writeup of the new Madone on cyclingnews.com. It has some really cool features.
http://www.cyclingnews.com/tech.php?id=tech/2007/features/trek_madone_launch07
