Oh swim gurus, please HELP! This is f**king ridiculous!
Okay, I understand that running is a damaging sport, with lots of impact, so accepted my plantar fasciitis as the simple consequence of being an old guy doing an activity that can lead to injury.
Biking is less of a stressor (in the anatomic, rather than physiologic, sense), so was a trifle surprised when - as I started to more consciously unweight my legs on the upstroke - I developed some hamstring pains. Okay, it’s a change in my biomechanics, and should smooth out when I improve my technique and efficiency, but an overuse injury from biking?!?
At least there’s swimming as the ultimate low-impact sport; and my pull is nowhere near strong enough (nor do I swim enuf distance - no more than 15K y/week) to cause shoulder problems. But - TENNIS ELBOW !?!?!?!?!? Over the past couple of days, have developed a classic lateral epcondylitis in the R arm, with tenderness over the lateral epicondyle, pain on extending fingers against resistance, weakness and pain on lifting with palm down, etc. There must be something wrong with my catch in order to stress this poor tendon.
The upshot is that I now have ‘injuries’ in every discipline. Wait, you say, you don’t have an injury in nutrition, the “fourth discipline”? You didn’t see the chocolate cake I experimented with the other night, and the damage to my position on the scales…
Seriously, any insight from swimmers on what I might be doing wrong - that could aggravate the insertion of the extensor carpi radialis brevis onto the lateral epicondyle - would be deeply appreciated! I don’t mind the “pain” of enduring aerobic effort - or even the burn of suprathreshold training - but sure as hell hate the fact that, as I sit here, I am icing both my foot and my elbow!
OK - not an MD, but a strong background in comparative anatomy and vertebrate biomechanics.
Have you been playing with the angle of your wrsit to your forearm anywhere in your stroke lately? My guess is that you are breaking your wrist rather heavily early in the catch to create a greater pull, and have hyper-extended the tendons in the process, or at least overstressed them. A lsight bend in the wrist is acceptable, but you should basically keep all the elements in a single plane for the most part. Also, if you are bending your wrist before your full extension, you will actually be pushing water forward with the back of your hand, and the natural attempt to stabilize that could be casuing tendon strain.
I have definitely been breaking the wrist - trying to face the palm to the back of the pool, once I’ve completely extended my arm, as a way of initiating my catch. I suspect the angle is likely around 75 - 90 degrees, so it’s a pretty exaggerated palmarflexion, and could certainly be stressing those pesky tendons.
OK -just got my wife’s tension band out and played around with stoke - there is another possibility as well. If you are trying to prevent a corssover in your pull, you could be causing some problems with the joint as well. Think of it this way. When you pull back, your humerus will reach a point where it is directly leteral to your body plane. Now, you4 hand should be realtively near the centre line of your body at that time. If instead, your hand is pointing to the bottom of the pool, it will be well to the side of your body and will be exerting a lot of pressure on that joint.
Bugger, this is hard without seeing your stroke and being able to show you.
And, as I do not want to be responsible for anybody to die of laughter, I have vowed never to post my swim stroke (or, even worse, my biking position!) anywhere.
I have had a problem with crossing over, and have tried to extend laterally as well, so may be doubly stressing the tendons. The other thing I think I may be doing is, in trying to ‘reach over the barrel,’ doing so by actually elevating my elbow relative to my shoulder as I drop the hand to grab the water; so that my hand is vertical, palm pointed to the back of the pool (not the bottom), my forearm is at a 45 degree angle to my body, and my elbow is lifting as I rotate my humerus; I think this actually stresses numerous tendons, while limiting my ability to use the power of my lats in the pull.
Any good drills you’re aware of to ingrain the right mechanics of the catch and pull?
swimming with your hands in a fist is a good one for cleaning up your arm position.
While I wouldn’t use them until your tendonitis is over, paddles are very good for showing up where you are generating force and generating resistance in your hand position. Have them as loosely attached as possible. You don’t need big paddles to do this, and watch stressing the shoulders when using them. I found I had a nasty early break in the wrist that meant I was pushing water when using this.
Other than that, the best thing I can suggest is finding a decent coach, even for a short time, to do a bit of analysis on your stroke. Get the corrective drills, go off and train them, then check in with the coach a month later and see where you are at. This is assuming you don’t want to go the masters swim route.
Thanks, Jim.
By the way, I see you’re from Charlottesville - I am likely gonna be there in April to do some teaching, and am looking into pools. I assume the UVA pool is pretty good - any thoughts?
AFC pool is great by all I have heard - except getting clear time around the swim club. I live just around the corner from ACAC gym, which has a lap pool which is better for me (since I am not affiliated with the university I would have to pay for either, and ACAC is closer). We have a pretty good tri club here - a smallish core of die hards and a fair number of recreational types. There is a regular Saturday AM run - you should really come and do the Charlottesville 10 miler loop - good solid training. There are also great routes in the county - anywhere from 8-15 miles runs. There are at least 4 group rides with the tri club run - for all levels of skill (beginners 18 mile up to 60+ mile 20 mph+ pace advanced rides). There are some people here on ST that swim at AFC - let me know if you need help tracking them down.
How long you going to be here? If you have time, there are a couple of nice sprint and Olys coming up in May and June. Give me a shout ahead of time - if you don’t have time to train, at least let me buy you a beer.
Sounds good - will be there in mid-April, a coupla weeks ahead of St Anthony’s, which I’ll be using as a training “B” race; I think current dates are 4/17-19. I’ll give you a shout when it’s firmed up!
