I’m trying to understand which way to go as I look to upgrade my wheelset. I currently have a Mavic Aksium set that came with the bike.
I’d like to get a nice pair of wheels that would work for everyday and racing. And look really cool in the process.
I’m guessing since I’m looking for an all around wheel it probably won’t be a tubular?
And how do I know what size I need? I think I understand general size to be 700cc. But when I look at some wheels I see values like 38 or 58 and I’m not sure what that means.
I’d, of course, like some carbon thrown in there. Doesn’t have to be a complete carbon wheel, I’m guessing if I wanted that effect for racing I could throw on a disc cover.
So how do I make an informed decision.
P.S. I’d go sit down at my LBS and ask a million questions but I’m recovering from surgery and thought I’d get started in a direction.
The 38 and 58 you are referring to is the rim depth in millimeters, a 58mm carbon rim like the Zipp 404. Are you just trying to look good? The Aksium is an ok every day wheel. If you want form and function I would suggest the Cosmic Carbone wheels from Mavic.
I got a pair of Rolf Vigors 4 years ago for the same aspect of training and racing on the same wheels. They have done very well with no issues at all.
As for sitting down with the LBS to discuss wheels, like asking questions here you’ll get answers some good, some maybe not so much. At the LBS you’ll get answers about wheels they have that may not be the wheels you want. Here at least you’ll get the opportunity to hear some good suggestions and some not so good ones but those opinions will not be biased by current inventory. I would suggest take the feedback you get here narrow your list then go to the LBS that carries the wheels you’re looking for to get the final questions asked/answered and to then make your purchase either locally or elsewhere.
I’d say keep the Aksium to train on and get a little bit better wheel to race on. When you get to a race you’ll be riding a little faster and with a little less effort with your race wheels, as opposed to the same effort and speed with the same set of wheels.
It is always hard to understand something when you want a something that does everything.
You want a wheel that is great for everyday and racing. Doesn’t exist. The wheels great for racing would be annoying to use everyday. Hard to change flats, damage is expensive, valve extenders, wind issues in group rides, and so on. forget it.
A disc cover can turn your everyday rear wheel into a GREAT race wheel for race day.
For the front, get a separate wheel. Hed, Zip, Flashpoint. Can’t go wrong with any of those.
If you want more details about sizes, see sheldon brown’s site for all kinds of great info here.
That said I’m going to be the boring voice of reason - get a custom wheelset built to your weight and needs. A set of ultegra hubs with some mavic open pros/CXP22’s can probably be just as light as a wheelset double the price. Get into an accident, lose a spoke, and most likely you’ll still be able to ride home (not possibly if you ride something with 18 spokes as the wheel will be completely dished once a spoke snaps) and, your LBS will be able to repair it very quickly.
Ultimately I’m a MOP with no delusions. Being able to have wheels repaired quickly and easily at low cost (ie. you might have to send back those fancy carbon rims/proprietary hubs) is worth a lot more to me now than anything else. I don’t need to spend 4 figures on wheels that won’t last, especially considering the crappy roads I ride on and the psycho drivers around me. I don’t need the fancy brake pads I need for carbon rims. Aluminum rims work fine for me and are easy to clean. And hubs, geez, a good hub makes a world of difference, in both comfort and confidence in corners and downhills.
HED Jet6 and the Carbones are both race-worthy and durable enough to train on. The Zipps are as well, but potholes happen and it sucks to risk $2K of wheels in training. Having dual-use wheels kinda comes down to how cool you want the bike to look/ fast you want it to be when training vs. the risk of taco-ing some expensive hoops.
My advice: Use the Mavics you have for training, and get a set of race wheels. For example, I train on some bombproof Mavic Ksyruims and put on a Renn disc and Jet9 to race. A rear disc and a 60mm deep front wheel (Jet6, Zip404, etc.) is the most versitle race setup (or a set of 60mm wheels and a Wheelbuilder cover for the rear wheel to make a vitrual disc).
As has been suggested in other threads, you could have a wheel cover for your rear training wheel that you put on for races and then you only need an expensive front, a hed or zipp, I’ve had zipp 303 and 808, loved them both.
