AC Carbon (Zipp 404 wheel with AC hub) with Tufo S3 Lite < 215 gram at 160psi
AC Carbon (Zipp 404 wheel with AC hub) with Tufo S3 Lite < 215 gram at 125psi
Hed Alps with Vittoria Corsa KS & Latex tube at 125psi
Hed H3 with Axial Pro Light & Latex tube at 115psi
The test was on an 8% grade course with power measured by an SRM pro. I only did the rear wheel since I got rid of my front tufo a while back.
It probably won’t suprise you that the AC with the Tufo did the worst. It actually performed slightly better with the lower PSI. However, the Alps-Vittoria Corsa and H3-Axial Pro combos beat it consistently in every trial.
Why not test the Elite Jet, since that is Tufo’s nicest tubular? How do you think that tire would stack up? It is a high TPI (400+ tpi), low weight (<165g) tire.
I haven’t done the complete calcs yet, because there were some slight power variations in the trials – one or two watts this way or that. However, it’s looking like ~7 secs over about 4:50 minutes.
Doesn’t sound like much. However, that means almost a minute and a half an hour. And that’s at a measly 9mph. Just for the rear wheel.
curious as to why you did the test on an 8% grade? On something like that, I think the wheels themselves would be more of a factor then the tires.
For this to be more of a valid test on a grade that steep, you might have been better off using the same wheel and changing the tire. Could be wrong though, I’m no scientist.
The reason for this is that I wanted to eliminate aerodynamic differences in the wheels and my body position as a factor. The low speeds (~9mph) on this grade accomplishes this.
Using analyticcycling’s calculator, I adjust the wattage for the weight differences between the wheel/tire combos, e.g. ~1.5lb difference between the H3 and the Zipp/AC. FYI, at the speed/power I used, the weight difference amounted to ~1 watt (out of 280).
The difference for just the rear tire comes out to about 10 watts. At 1200 watts, or whatever you do in a 200, 10 watts (or even 40 watts) is noise. For an AG triathlete, whose average power might be under 200 watts, 10 watts is a big deal.
