i would be interested to hear any replys my h3 is similar.if i spin it in hand it spins forever so dont think it is due to busted bearings.
this was a problem i had with mavic cosmics b4 spun in hand like a brake pad was rubbing it turned out instalation of bearings was done wrong
Not sure if this will help in your case. I bought a used set of Hed 60’s which spun freely by hand but would bog down when clamped in the fork. I changed the sealed bearings but it didn’t help. I noticed that the seal on the bearings was slightly deformed so I suspected that the machining is off and that the skewer was putting pressure on the seal which in turn puts friction on the bearings. These Hed wheels don’t appear to have any way of adjusting the load on the bearings.
I pulled the metal\rubber seal out of the bearings and clamped it in the fork, and the problem was solved. The front wheel when spun by hand went from 1.5 minute duration to 8 minutes in duration. These are race day only wheels so I will leave the bearings without seals and just use grease.
i wondered about doing this as have seen it reduces friction
i guess you would reccomend but how much maintance is required and is there risk of damaging bearingsor if well greased will bearings still last
also any advice on different grease to use for best performance
I probably wouldn’t go this route for everyday wheels because of the amount of rain \ grit etc getting in there. When you take the seals out you end up with basically a similar type of set up as the old loose bearings and cones which often only had a dust cover.
After a seasons use I pulled them out and re-greased them which maybe took a half hour. They didn’t appear to be particularly dirty or rough.
Just used regular bearing grease.
thanks my h3 is pretty much race only, little bit of training around racs just for handling.
might mail hed and see if they reccomend or not
was just wondering was it goin to cost me money on bearings or just a bit of occasional time greasing bearings
