HRM Help - Polar won't stop beeping
Just got a new 7201. I’ve set up an easy interval exercise set: 5min warm-up, 3 intervals of (5min hard/1min easy), then 5mins cool down. I’ve switch off HR Limits on all three timers, but even still when I transition from hard->easy the timer stops as my HR is too high, then when moving from easy->hard it stops because it’s too low.
Any ideas of how I can stop this happening? I just want to record the HR data. I don’t want it interfering with my session.
press and hold the button for the light this might help turn off the beep/chime.
hit it with a really big hammer…or…a rock if one is nearby.
Sounds like you might have the interval set to be a neart rate interval not a timer interval.
When you go through the settings, the first time it says “interval” at the top it should say “timer” in the big letters in the middle. This tells the thing that you want to do intervals based on time.
If it says HR, then you are telling the thing that you want to
In fact …
I’ll get mine out and see exactly how it goes.
Buttons are red button, “enter”, bottom left “exit” top right “up” and bottom right “down”.
Top line is in ** asterisks
Starting at the time of day screen.
up, up - now it says options
enter - exe set
enter - exe set and “1”
enter - Interval; at this point up or down buttons to select which one you want to program, for the moment let’s assume number 1. When it says exe set and “1”,
enter - Interval scroll up or down to select On
enter - timer 1 scroll up or down to select on
enter - timer 1 scroll up or down to set minutes to 5.
enter - timer 1 scroll up or down to set seconds to 0.
enter - timer 1
up, up - Interval and either timer or manual, or distance, or Hr
scroll to set it as Timer
enter - Int timer scroll up or down to set minutes to 5
enter - scroll up or down to set seconds to 0
enter - back at Interval and it should say timer.
up - repeat and a number or CONT
enter - scroll up or down to set repeat to 3.
enter - back at repeat and it should say 3.
up - limits2 nothing to see here.
up - recovery and timer, dist, or hr, the bottom line says either on or off
enter - same screen but you can scroll up or downto select off or on, select on.
enter - same screen, scroll to select timer
enter - scroll to select minutes as 1
enter - scroll to set seconds to 00
enter -
up - now it should say timer3 and a time and on or off.
enter - scroll to select on
enter - scroll to select minutes to 5
enter - scroll to select seconds to 00
exit exti exti , keep going until you see the time of day again.
When you want to start, hit the button once quickly until it shows HR.
Hit the second time to start warm up
Feel the burn.
Nope, all sections are definitely set to TIMER. I guess I’ll email Polar and see what they say.
I think I know the problem.
Let me check… hmmm, yup, I’ve got it. It’s a polar.
Just messin with ya, though I’ve not had good experiences with my polar.
