How we cured our dog's epilepsy (long) but hope it may help
no, which is why i want people to stay away from quackery.
So your opinion is that medicine always works? Man, you really need to come back to reality.
im not claiming to be more qualified. .
Not directly, but when you claim to have a better answer than the Vet, it sure sounds like you’re implying it.
“Put your dog back on the original food. If that is what caused the seizures in the first place, they will quickly start again.”
That would be the logical thing to do if I was trying to prove something from a science perpective, although I doubt if even that would convince people like veganerd or Vet A to remove their blinkers. But it won’t happen any ways. Our dog is a family member, not a lab rat.
Except that Vet A didn’t even claim that phenobarbitol would “work.” Vet A claimed that the drug would reduce the seizures. Cerveloguy got a superior outcome. If you would prefer to have your dog experience continued seizures instead of trying an alternative, that’s certainly your perogative. in the meantime, those of us who live in the real world will keep trying alternatives that might produce better results, especially when the risk is fairly obviously low.
regardless of how many times you repeat it, it wont make it true. you have no freaking clue that what cerveloguy did produced any outcome in regards to epilepsy. NONE, ZERO. i realize you think you do because you are confusing correlation with causation. how do you know that a neighbor wasnt blowing a dog whistle that triggered the seizures? how do you know that the seizures werent triggered by a color pattern? how do you know that they werent triggerd by lack of sleep? no one here knows what triggered the seizures or what made them go away.
if you think the risk is low then you simply have no idea how dangerous epilepsy is.
“no one here knows what triggered the seizures or what made them go away.”
Wrong. I do.
**So your opinion is that medicine always works? Man, you really need to come back to reality. **
how the hell did you make that leap? youre usually much brighter than that.
this is the best treatment for idiopathic epilepsy in dogs.
I’d have to say that in this case I found a much better way. You’re way too predictable.
correlation =/= causation
“follow the science based medicine.”
Because throughout history science based medicine is always right and nobody has ever died because of it. Tell that to the estimated 55,000 Americans that die of prescription drug reactions or complications every year.
And yet, plenty of studied treatments have harmful side effects as wel
Yes, that is the point. Almost all treatments have side effects. Difference is that studied treatments have KNOWN side effects and non studied ones don’t. When a doc prescribes a treatment they know the effect as well as the side effects and harm. If the harm is greater then the known result they don’t prescribe it. Hard to do that when you don’t know the side effects or even the effects.
Again with this strawman argument. Nobody is advocating for people to ignore medicine in favor of alternatives.
Save the OP who refused to US** **phenobarbital and went with the alternative.
The OP is clearly recommending, at least the way I’m reading it, that people ignore vet “A” who is suggesting known and studied forms of veterinarian medicine in favor of vet B’s “recommendation” that the alternative is “Soemthing to try” without any scientific evidence over the phenobarbital.
You may call that a strawman, I call it reading the OP. YOU may not be arguing this but the OP clearly is stating this is what he did and alluding that vet “B”, now being a “Believer”, will now recommend this.
~Matt
Wrong. I do.
no, you apparently dont. you think you know but as we keep saying correlation =/= causation.
which specific ingredient was it that you think was doing it and in what amount?
seriously man, youre going off the deep end with this post, come back to shallow waters my friend.
“The OP is clearly recommending, at least the way I’m reading it, that people ignore vet “A” who is suggesting known and studied forms of veterinarian medicine in favor of vet B’s “recommendation” that the alternative is “Soemthing to try” without any scientific evidence over the phenobarbital.”
What I am saying is that had I followed Vet A’s recommendation to use phenobarbitol is that my dog would still be having epileptic fits and running risks of serious drug reactions based on the known science of this approach. But what should be obvious even to you is that the alternative approach we took had a much better out come even if we don’t yet understand the mechanism why.
Yeah, I’m sure that cerveloguy had a neighbor secretly causing ear infections and epilepsy in his dog through a magical dog whistle. You’re really reaching. All science requires that we look at the most likely causes for things before we start imagining crazy possibilities.
Read cerveloguy’s account again. He got medical opinion from a licensed veterinarian that indcated that the infections were likely caused by allergic reaction, based on ruling out some other possible causal factors. He took the dog in for additional testing and got additional professional medical advice to try changing foods. Cerveloguy didn’t change sleeping patterns or color patterns or magical dog whistles. He changes foods and saw immediate response. He changed foods more and got an even more pronounced effect. As I said, proving that the food change worked and knowing that it did are two separate items.
If you think the risk I was referring to was the risk of epilepsy, then you don’t read very well. The low risk I was referring to was the risk of trying a change in food.
I asked if you wanted people to pour money in medical treatments that don’t work. you responded with “no, you warn people to stay away from quackery.” the clear implication is that medical treatments that don’t work are quackery, and by extension, anything that isn’t quackery must always work.
If that’s not what you meant, you should be more clear.
"which specific ingredient was it that you think was doing it and in what amount? "
That I don’t know and unless I was to start to introduce ingredients one at a time until my dog threw an epileptic fit we won’t know. But as already mentioned our dog is a family member and not a lab rat. All I know is that the alternate approach worked for us. Hopefully it may work for someone else.
The actual difference is that studied treatments have known and potentially unknown side effects. We find new side effects in “studied treatments” all the time.
Let’s not start to worship at the altar of science and pretend that just because a treatment is studied or even accepted by the medical community, it is somehow infallible or that a study means we know everything about how that treatment will work for every person. That’s a dangerous road to go down.
Hard to do that when you don’t know the side effects or even the effects.** **
And what do you imagien were the potential unknown harmful side effects of recommending a dietary change for this dog? I’m not suggesting that any and all alternative suggestions are equally safe or valid. Nobody is suggesting that people should just blindly try any alternative they read about on the internet.
Save the OP who refused to US phenobarbital and went with the alternative.
Please show me where he recommended that anyone else ignore their vet’s advice? I think he simply suggested that people consider diet as a possible change that could help with epileptic dogs, which advice was, by the way, partly based on the advice he got from one of his vets. Funny how you keep ignoring that part.
“i want people to stay away from quackery”
Just curious as to what makes you the all knowing authority on what is quackery and what isn’t?
And what I’m saying is, you know this how?** *Isn’t quite possible possible the pheno would have worked? From the first google I did. "*Complete control of tonic-clonic seizures for 6 months, at least, was attained in six out of fifteen dogs of the phenobarbital group, and in five out of twenty dogs in the primidone group."
But you don’t know that the “Approach you took” is what actually caused the change.** **You changed diet, something else changed. That’s all you know. You do not know that the change in diet caused the change. What I’m saying is that for you to reccomend the same approach is to do so without any knowledge that it will either work again or that in fact for another the phenobarbitol is not a better approach.
Don’t get me wrong, I’m all for the idea that sometimes science lags behind and that individuals can and do come up with approaches that are later proven to be better then what is currently known. What I’m saying is that when this happens, until proven, you can’t simply say “My approach is the way to go” over known science. For some, maybe many, the unknown alternative approach may end up being more harmful then the scientific one.
~Matt
heres the actual quote.
In your mind, is it a better value to keep pouring money into medical treatments that don’t solve the problem?
it was a snarky quip that quackery doesnt solve the problem so i fell people should stay away from it. that does not translate into medicine always works.
“you can’t simply say “My approach is the way to go” over known science”
I’ve never said that. I’ve just told a true story how we cured our dog’s epilepsy using an alternative approach in the hope it may help others who may be desperate for something to at least try. Maybe there is science to this but at this time its not known. But I personally don’t need a double blind clinical study in some peer reviewed science journal to convince me what we did worked for our dog. We saw it with our own eyes - three years now and not a single fit. That’s quite an improvement from the one or two seizures he was getting weekly before we started experimenting with his food choices.
Nothing is perfect, that’s not the point. The point is that having known effects and side effects, studied effects, is several factors more information then simply assuming about a single effect.
The obvious one that pops to mind is that the change in diet has no effect at all and the dog continues to suffer where as a known scientific approach may have worked. The side effect being that the dog continues to suffer. Even if the known scientific approach didn’t work it IS known how long it should take for it to work where as the “Diet change” is a complete unknown. How long do you let the animal continue to suffer before you say “Well I guess this isn’t going to work”? Some parents do this with prayer…all the way until their children die.
Not sure how you interpret this, but I interpret as “Don’t do pheno, change your dogs diet”. Since a vet advised him to do phenol he is essentially saying “Ignore your vets advice if they say take pheno”
Does he come right out and say this in the exact wording you are asking for, no, but I’m not sure how you can read the OP and this statement and not come away with this. HE does not say “Change diet AND take pheno”, why? because he ignored the Vet’s advice to do so because he didn’t think it would work and it had “Side effects”.
~Matt** **
