How to tell the difference between hot and not recovered?
I just raced CDA and am planning to race FL in November. This will be my first time to do 2 IMs in one year. I am in the middle of a self-imposed 6 weeks of base/recovery/lower HR training period before I head back into full swim FL training.
Question now is how much is/does the heat usually slow everyone down on the run? I’m in Houston, so it especially awful here this year, but I missed a good part of the onset of this heat as it came during my CDA taper. I ran 8 this morning (longest I’ve run since CDA) and it all felt fine, but I had to slow way down to keep my HR in zone 2 (under 85%). I’m probably running 1-1.5 minutes/mile slower right now than I was in May for the same HR effort. If that is all due to the heat, no problem, I’ll deal with it, but if it is due to me not being recovered from CDA, I’d hate to never fully recover and dive back into FL training and just end up a big unrested mess!
As a side note, recovery from CDA is super important for me as I ended up super sick last fall after a full year of racing (may have been overtraining, may not have been, will never know, but don’t want to tempt my body to go back there again…I was running 11:30 pace at a heart rate close to 200).
look for other signs that would indicate you’re not recovered - fatigue, soreness, moods, sleeping patterns, interest in training, etc
run when it’s cooler (indoors?) and see if you get the same HR results
hey there Kw trigirl. im in houston as well(in fact u know me :)…i typically do well in the heat,but i would say your pace will be off roughly 15 sec-1 minute a mile? this can vary tremendously depending on how you do in the heat,hydration levels,fatigue,etc.etc…i would think your recovered from CDA by now. its been 3 weeks right? i would adjust your pace,slow down and listen to your body. IM fla. is way off from now and youve got a huge base from already having done an ironman. if i were you i would focus on speed/more intense training for a 6-8 week time period and then do a short build up for fla. for about 8 weeks…PM me if you have any questions on doing back to back IM’s…ive done a few.
jethro
What about HR for swimming if you aren’t swimming in a 90 degree outdoor pool? What about resting HR? Do you do any indoor cycling class or other activity where HR is higher? Look at other factors.
You might just need more recovery time and you have plenty of time for IMFL. Check pre/post weight before run.
The heat slows me down. Near coastal SC so probably just a little cooler than Houston. I lost at least 4.5 pounds in a 70 min run today and drank 40 oz during the run. Didn’t weigh myself until after I ate and drank more so proably lost 5.5. HR was also higher. I can usally run easy with HR of 135 at a 8:45 pace and HR was 150 running slower today. It was hot as I didn’t run until noon as my lazy but sleep in and then parked on the sofa to play on ST.
What is your training and sprint racing HR? Do you know you max HR? 200 is probably on the high side.
hey girl, i have been having the same problem and don’t really know what is going on. I did CDA too and took about 2-3 weeks off, just doing a little here and there. I rode my bike the other day (inside on the trainer)-easy with low watts- but my hr was so high. Then i went running the other morning and my hr was high again despite a slow pace, i couldn’t get my hr down at all with out stopping to walk. The efforts didn’t seem hard at all and i wasn’t trying to go hard or fast at all. I don’t think it is heat related and I’d like to think that now several weeks out I am pretty much recovered from the race. I have AZ coming up in Nov. and would like to get to my plan for that. I did LP last year but broke my pinky toe a couple weeks after that so had to take 6-8 weeks off while that healed- so i can’t really compare this to anything else. I’m in AZ and it is plenty hot now but i am starting to think that that is not the whole problem.
Do you track your morning HR before you get out of bed? Rule of thumb is if it’s 10 beats or more higher than normal, you may need more rest.
Soreness/interest/moods seem to be ok.
I have run indoors on a treadmill twice in the last year+, so I do not necessarily have much to compare against there.
I did ride 70 miles today and it wasn’t that bad. My HR went through the roof, but not until I got “kidnapped” by “friends” and went way faster than I had business doing…my HR would skyrocket any time that happened, so I don’t necessarily think that meant I’m having too many recovery issues.
Sounds like we’re in a similar boat!
Hopefully we are able to distinguish between fatigue/heat/out of shape before too long!!
I am trying to keep everything easy until the beginning of August. I rode 70 today but won’t go that long again for a few weeks and will keep my “long” runs to no more than 8-10 easy miles…which may take all day!!
I have tracked it on and off here and there. I just put my garmin on and take it while I sleep. My “resting” (when I was awake to see it) seemed higher than it had a few months ago, but my actual average over the ~9 hour period I wore it was exaclty the same as the few others times I had slept in it over the spring, so nothing obviously alarming there, yet, but I plan to check it a bit more often over the next few weeks to see how it is going.
It’s the heat/humidity. I’m in the Houston area and well aware of the impact our weather has on training. Difference between winter and summer run times are easily 60-90 seconds/mile for me. Bike power is typically off ~10% as well. This summer is probably the worst ever, though Saturday actually felt “cool” due to the north breeze and “low” humidity. Even with that the heat was draining.
I live in the mid-town area of Houston and work outside so I perspire a lot. I have found that using Hammer Nutrition Endurolyte capsules twice daily ( 1 in the am and 1 in the pm) really help me out. That and hydrate!!!
