How to remove driveside Powercrank
Can anyone tell me how to remove the driveside Powercrank. I removed the left side cranks as specified using a cank puller, but as the driveside crank has the opposite thread I cannot use the crank puller. Is it possible to get a crankpuller with a thread that fits the driveside?
you do not need a crank puller. just turn the mounting bolt out and let it push against the large silver end cap. crank easy till the bolt hits the inside of the cap, and then crank harder and it will remove itself. now, twist off the silver end cap and you are done.
