How to reattach cloth on profile design arm pads
Any suggestions on reattaching the black cloth on my arm pads on my profile design aero bars? The pads themselves are fine. I don’t feel like spending money to replace them since they work fine. I also could just leave them as is. Anybody use some sort of fabric glue to reattach them?
I haven’t done it myself, but I suspect “Shoo-Goo” should do the trick. Bonds fabrics well and is waterproof.
i went through this problem with a few different takes. the last was the most successful, but not perfect.
first i made big efforts to reattach or restuff the loose sides in. that was only good for the next couple of rides.
then i got similar material (i had on hand) and covered the whole pad and cinched it below with a tight rubber band. this worked, but it pulled out once or twice, and i had to do a major fiddle with the raw and raggedy ends, which i didn’t want to show.
lastly i improved on the latter plan, but actually sewing it shut underneath. i took care of the loose ends during that process, so it looked and felt smooth. sewing those on, the way i wanted them to look, was a job that required some skill, patience and being a bit of a contortionist. but it worked.
peggy
I didn’t think of shoo goo. I do have some other fabric glue I’m going to try first.
I’m going to try glue first. If that doesn’t work I’ll try sewing it.
