How to do a valid feild test with power meter
I wanted to test the difference between rotorcranks, q-rings, and regular cranks. There is a 2.25 mile climb near here that I was planning on using for the route and a power tap for the measuring device. The plan was to warm up on the rotor bike for 15 minutes and then do the climb recording HR, watts, and time. Then do the same (including warm-up) on the bike with q-rings (same measurements as rotor bike), and then switch the q-rings out on that bike and ride round rings.
Does that sound like it would yeild valid results?
Appreciatethe help.
Brian
uh…
no.
Go down to Chapters and buy Thomas Chappel’s book “Base Building for Cyclists”, Nov. 2006. I don’t have a power meter, but the book is all about training using wattage and HR. Cost me $23 cdn. Has about 50 pages worth of fitness tests and equations.
Would you care to elaborate?
the scientist in me says no, but for what you’re doing it should be ok.
this is a case study (sample size = 1), so the results aren’t really generalizable, but you’ll get an idea of what YOUR differences are on the equipment (which is your point, right?).
you will want to control the effort each time though (through either HR or power) so that you don’t die on the last one (from pushing too hard on the first two), and so that the results are comparable between trials.
good luck with that,
I appreciate the info, but I am not trying to do a test to find out my training levels. I am trying to figure out if some of these gadgets I have are worth keeping around, so I am wodering if I can compare them or I have to believe the data on rotor’s website.
Thanks
Usually when you’re doing an experiment you’re gonna wanna keep the variables as limited as possible. In your case it could be alittle difficult… are you going to do the experiments back to back to back…or day after day after day…My concern would be that after doing the climb, you might unintentionally ride it differently. Power might be the same, but different cadence and heartrate…and so on… Or the third time you might be alittle better physically than the first or on the otherend more fatigued. That is gonna be a hard experiment to keep all factors the same. Especially considering the results might be only slightly different, how are you really gonna be able to interept them…
You might have to do it in a more comprehensive way, if you’re serious about this. Like do this experiment 3 different times… doing each climb with each crank just once and comparing that data is too foggy in my opinion. I’d say you’d have to give each crank atleast 3 runs each, but limiting these variables is gonna be almost impossible.
sure. These cranks/chainrings you are testing aren’t going to magically get you up the hill on less watts. Assuming that your position and the air around you is identical in each test - its going to take you the same amount of watts to get up the hill for the same split regardless of what you crank you are spinning.
Regarding your heart rate - there are just too many variables as to why your heart rate may be higher or lower during a given run and depending on which set of cranks/chainrings you are on. Just because your HR was lower on one run with the same power output on one set of cranks doesn’t mean that you are able to sustain more watts over a given period of time than on the other set of cranks.
You asked if it this test protocol would provide valid results and the answer is no.
So would it be better to use rollers? I was planning on a hill since these other crank systems are suppose to be “better” on hills more than flat.
You may want to instead use a computrainer
http://www.rotorcranks.com/pdf/q-ringstest.pdf
For this study 8 volunteer Elite-sub23 amateur cyclists from Galiber Cycling Association were used as test subjects (n=8). The study was held during first and second week of training, so it was coincidental with the time in which training starts for the coming competition season (2006). The average age of test subjects was 21,1 +/-2.1, weight of 69.3 +/- 8,4 Kg., height 175.8 +/-5.9 and Max VO2 70.5 +/-5.3 (ml.Kg-1min-1).
For lab tests a trainer from the brand COMPUTRAINER™ was used, which combines an electromagnetic with an aerodynamic brake, as well as the tire-trainer friction. This trainer machine controls the resistance applied to the wheel by computer. Even so, tests carried out using this trainer, as would happen with any other model or make, cannot guarantee that the results attained would be valid for real world cycling on the road. The advantage is that this computerized trainer allowed for each cyclist to use their most suitable Q-ring regulation setting, thanks to SPINSCAN, a tool which provides information about each individual’s pedalling style. Moreover, every cyclist could use his own bicycle for the test. For all tests, same rear wheel (the one subject to friction) was used at the same inflation pressure (8 atmospheres) and for every bicycle, a set of OQC (Q-rings) or NCC (Normal or Circular Chainrings) were used, depending on the correspondent test.
Two days before tests were carried out all test subjects were summoned to the lab to inform them of the study objectives, tests to be done and get their written authorization to proceed. Additionally, clinical backgrounds (history) were collected and physical examinations were carried out. In the same manner, blood specimens were taken for a subsequent biochemical and haematological study, in order to know the physical condition and biological profile of every tester. These tests allowed the exclusion of any subject who could display any signs of pathological illness, or those who were out
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 5
of the range of normal physiological profiles (Criteria by UCI-2005 Medical Committee). The group of the cyclists who were initially to use the OQC pedalled on their bicycles with NCC for 5 minutes on the COMPUTRAINER, in order to obtain SPINSCAN results. According to these results, indicating whether their SPINSCAN was high, medium or low, the OQC were regulated for their bikes. For the other half of the cyclists this was not necessary, because they were to test NCC first, so the SPINSCAN could be made then for them during these tests, determining each subjects optimal regulation for OQC.
So, proceeding every OQC test, the Q regulation, or orientation of the crank in relation to the greatest diameter of the oval chainring, was determined for each individual cyclist.
On the same day of lab tests, blood specimens were taken from each athlete’s medial basilic vein. These samples were taken before and just after the maximum effort test on their own bicycle, coupled to an ergometer, in order to determine changes in blood variables.
For analytic veriification we used an auto-analyzer for blood determinates (Coulter Electronics, Ltd.) and biochemicals (Hitachi). Lactate measurements were made, previous puncture with sterile lancets (Boehriinger ®), with micro-method system “Lactate Pro” (digital with testers), based on an amperometric method using and enzymatic reaction. This apparatus requires only 5 Tl, with a variation coefficient of only 3%. Likewise, at the same time measurements were made with an “Accusport”, whose results are based on enzymatic method and lactate reflex photometry (with a wavelength of 660 nm). These measurements were made using 20-30 Tl pure blood samples. This method has a good correlation, r=0.90 & r=0.97, in determinations related to YSI 1500 analyzer (reference analyzer used for the validations). Samples were taken before the start of the test, and 1,3 and 5 minutes after finishing it, in order to obtain the maximum lactate levels.
Recordings of the test subject’s Heart Rates were taken and saved continuously using a heart rate monitor (Polar – Xtrainer Plus).
Gas composition was monitored breath by breath for the duration of the tests (Medical Graphics System CPX-Plus). For the day before the test, cyclist were recommended to do some light training and eat a diet rich in carbohydrates. Variables calculated on the test were oxygen consumption (VO2), ventilation (VE), Oxygen
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 6
Ventilatory Equivalent (VE – VO2 – 1), respiratory quotient (RER). Subsequently, ventilatory thresholds were measured, attending to the increase of VE-V02-1 without the increase of VE-VC02-1 criteria for the VT1, and increase of VE-VO2-1 in parallel to the increase fo VE-VCO2-1, to obtain the VT2.
STUDY PROTOCOL.
Tests were carried out in three sessions of two days for all test subjects, in different weeks.
During the first and third week, tests were carried out in two consecutive days, for the first day half the group used OQC (regulated for each test subject individually) and the other half used NCC, and on the second day vice versa. Protocol held consisted of 15-20 minutes warm-up on the trainer, and after that a load of 200W (watts) for 4 minutes, prior to the incremental test. The progressive incremental test started at 200W, and from the 5th minute on, 10 watts were added per minute till the tests subject’s exhaustion. Gearing used by cyclists was free, but always maintaining a pedalling between 85 and 95 strokes per minute, so cadence stayed around 90-91 pedal strokes per minute. Along the test 4 blood specimens were taken from the test subject’s fingertip in order to measure blood lactate levels. Whenever these samples were taken, the time and heart rate were recorded. After 15 minutes recovery pedalling without resistance at 130 heartbeats per minute, the test subject made 4 maximum effort sprints for 20 seconds each, with 40 seconds for recovery in between them. Just before sprints started and at the 1st and 3rd minute after sprints, blood specimens were taken in order to analyze lactate levels.
During the second week, tests were also done over two consecutive days, with half of the group using OQC for the first day and the other half NCC, changing the chainrings around for the second day. Time schedules and conditions were as identical to those of the previous week for every cyclist as possible. The first test, consisting in a sub-maximum trial at 90%, was carried out after warming-up for 20 minutes on the trainer. This 90% was calculated bearing the results from last week in mind. These levels were defined using the average maximum wattage attained by every individual test subject for each chainring type (OQC and NCC), from which the 90% was calculated. Trials consisted of constant pedalling at 90% Wmax for the maximum possible time. As with the protocol from the previous week, blood specimens were taken at the end of the trial in order to define lactic academia. We must remark that during first day, if the test subject endured this test for over 25 minutes, he was stopped, scoring heart rate and lactate. On the second day of testing, tests were ceased when the test subject continued 8 minutes over his time from the previous day, at which point the subjects heart rate and lactic academia were recorded.
Data presented are arithmetic averages from every moment analyzed, for the scores taken with OQC and NCC.
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 7
RESULTS.
Results obtained are displayed as an average of all data for each of the analyzed circumstances, and are displayed on the following charts (1,2,3). For explanation of the results, statistical variations of results were not considered, due to this being a preliminary study, so more attention was focused on evidential biological characteristics. Obviously, for a bigger group of test subjects and with control of parameters considered as optimal, it would be necessary to do a statistical analysis of the results, so they could be properly published in a scientific publication.
It is observed in the results that when cyclists made the test with OQC they produced slightly more power (around a 3%), together with a slightly lower heart rate (around a 2%) during the progressive incremental test (chart 1).
For the 90% maintained power test, it was observed that with OQC cyclists were capable of continuing for a longer period of time than with NCC. Although there was a significant difference, this has not been numerically quantified as explained by both the statistical discussion above and the fact that tests were ceased when test subjects continued for longer than 8 minutes over times from the day before. This test resulted on a lower production of lactic acid for tests carried out using OQC. Nevertheless, average heart rate measurements during these tests showed no significant differences between OQC or NCC chainrings (chart 2).
For the repetitive maximal sprints for 20 seconds with 40 second recovery interludes, three of the four tests (first, third and fourth) showed that power production was higher with OQC than with NCC (chart 3). The second sprint test showed no differences.
Regardless which chainrings were used, (OQC or NCC) maximum levels of Heart rate and oxygen consumption (VO2 Max) saw no change, which seems logical because they were test where every individual had to keep on pedalling until his maximum (until exhaustion).
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 8
Chart 1. Analized Variables (W, HR-Max , X-HR) on Incremental Maximum Test with Q-Rings (OQC) and Normal Circular Chainrings (NCC).
CHAINRING TYPE WATTS (W) MAX. HEART RATE (HR max) (bpm) AVERAGE HEART RATE (X-HR) (bpm)
OQC 361+29.6 190+8.3 166+9.6
NCC 349+28.8 191+5.1 170+9.1
DIF (∆-%) 3.3 = 2.3
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 9
Chart 2. Analyzed variables (La-Max, HR-Max) on 90% sustained power test (90% of power showed on incremental test) generated with Q-rings (PQ) and normal conventional chainrings (PN).
Chainrings Lactate concentration (mmol.l-1) Max Herat Rate (HRmax) (bpm)
OQC 11.9+2.9 189+6.9
NCC 13.1+4.1 190+5.4
DIF (∆-%) 9.1 =
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 10
Chart 3. Analyzed Variables (W, HRmax, X-HR) on consecutive short sprints, Developer with Q-Rings (OQR) and Normal Circular Chainrings (NCC).)
SPRINTS NCC OQC DIFERENCE NCC vs OQC (∆-%)
S-1 685+100 715+74 4.1
S-2 578+62 582+47 0.6
S-3 499+71 526+78 5.1
S-4 476+74 510+84 6.6
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 11
DISCUSSION.
The Fact of not finding differences on Maximum Oxygen Consumption (V02 max) is not considered relevant, because is a maximal test no variations on this aspect where expected. Inciding on this, and concerning to other studies comparing elliptical and circular conventional chainrings’ other authors didn’t find differences either (12, 15, 20). For example, Henderson et al. (20) found out that maximum VO2 was not different on non fitted cyclists when pedalling on a Monark cicloergometer equipped with circular or oval chainrings for powers of 50, 100 and 200 W. Cullen et al. (12) didn’t find relevant differences either, neither in max VO2, nor in heart rate during a sub-maximal test using circular chainrings or elliptical on trained cyclists.
Nevertheless, relevant facts were found. The most significant in this preliminary study has been to observe that when cyclists did the 90% on established maximum test (average of all measurements obtained with OQC and NCC), they were able to maintain the effort they were required for longer when using OQC. Besides, on the sprints made after the maximum effort test, cyclists using OQC were able to release (although only a small percentage) a higher power on each of the sprints, in comparison when they were using NCC.
Another remarkable fact of this study is that after 90% power maximum effort test a lower lactic acid production was observed at the end of the test, even when same heart rate was reached. This fact can be understood as an indicator of a lower metabolic requirement when using OQC in comparison with the NCC requirements, moreover when it comes together with a longer effort time at a 90% of the maximum power.
The fact that during repetitive sprints a higher power delivery was scored by the OQR against NCC, could be understood also as a higher biomechanical efficiency indicator, together with the previous noticed better metabolic efficiency. So, on the same maximum test consisting on 4 sprints, a power delivery of 4% higher for the OQP was obtained. Even when this percentage differences are small, in the sphere of high level competition they could be decisive for the final result, especially on continuous and maximum effort exertion seen in disciplines such as Time Trials.
Given the fact that no difference on Oxygen Consumption was found between the chainring types, this could suggest that physiological demands were non significant. This would be coincident with Kautz’s and Neptune’s opinions (3), authors whose opinion is that internal work to move the legs could be not independent from external work to overcome pedal resistance. But in our study, even when no relevant variations in maximum heart rate and maximum oxygen consumption are detected, from a metabolic point of view, a lower lactic acid production is observed in the 90% sustained load test. Inciding on this, in a study carried out by Santalla et al. (19) analyzing Rotor Cranks pedalling system, (also aimed to eliminate pedalling dead spots), an improvement on mechanical efficiency was observed. These authors (19) explain this in that when the leg is on the pushing faze from the highest position, it could help the other leg’s work, which is involved in maximum descendent force application.
Normally legs are accelerated and decelerated by the muscles, resulting in an increase and decrease of the energy supplied. But with OQR power delivery seems to be more continuous, with less variations, (which is confirmed by the cyclist who made the test’s impressions). This could explain why lactate production is lessened in some fashion simply by the contribution of a continuous and harmonic pedalling. These changes on the energy flow for the external work, incise on the requirements for the internal work mentioned before.
UNIVERSIDAD DE VALLADOLID ESCUELA UNIVERSITARIA DE FISIOTERAPIA Tfno: +34 975 129187 Prof. Alfredo Córdova Martínez Fax +34 975 129101/02 Dpto. Bioquímica, Biología Molecular Y Fisiología a.cordova@bio.uva.es C/ Nicolás Rabal, 17 - 42003 SORIA (SPAIN) 12
Altogether, we think that, for experienced cyclists whose muscle coordination is already perfect, the use of a chainring providing certain energy savings could be beneficial. This, especially in situations where a maximum effort is required such as in time trials, sprints, spurts and climbs. Apparently, regulation settings of Q-rings could be the key for the differences in performance obtained.
Considering previous arguments, we consider it necessary to carry out a complementary electromyographyc study (EMG), together with a metabolic study analyzing the biomechanical factors affected by physical activity. These tests would need to be carried out in both in lab as presented and in the field (for example a training ride of 3-4 hours). This study could provide valuable information in order to check the improvements in pedalling efficiency ascertained; to define which circumstances OQC would be beneficial in and to what degree, so referred pedalling optimization could be customized. Q-rings’ novelty regarding their regulation options can contribute to a more precise vision of physiological, metabolical and biomechanical variations arising from non circular chainring use.
Pick one morning per week for the next few weeks and perform the “test” on your course. Try to control the previous week’s volume and weekends workouts to get some consistency. I did this back in November to compare a couple of different systems on the bike and though I certainly wouldn’t expose my “results” to the slowtwitch mafia’s derision, it was enough for me to formulate some conclusions. If you are doing base right now then a 2.25 mile climb won’t kill your whole week’s efforts. Just ride it as hard as you can using each of your test items and then compare the hr, power and time afterwards. I would recommend at least two repetitions of each, but more is better. Cycle through the gear in order and then repeat so improvements in fitness are spread out over all your tests.
If you are in more of a hurry then you could do it twice a week, but consistency is the key to finding out anything remotely valid.
And don’t tell slowtwitch your results afterwards; it’s not worth the grief.
Chad
P.S. If you are thinking of using the gear in triathlon then you really should run afterwards. Any bike testing I do on old or new gear is always bike/run else what is the point?
What he said.
I wouldn’t bother trying this test with heart rate.
However, I think a maximal effort test might have some validity. For me at least, maximal efforts for 1-20 minute durations (when reasonably rested) are suprisingly consistent.
If you try each setup a few times on separate days, and one produces consistently higher power (say 10 watts), I’d go with that setup. If nothing else, you’ll have the placebo effect working for you then.
I would not test it on a Computrainer, because the inertial effects are very different – even more so with non-round rings like the q-rings. It’s not clear how this translates to the real road.
– jens
I would fire your coach if I were you.
There’s nothing really surprising about that.
OK. You’re fired (since you’re the closest thing I have to a coach). The reality is, if you train well consistently, you’ll be close to your physiological limits for these durations and you’re not going to see that much variation from one week to the next. Maybe over the course of a year, but not from one week to the next.
  • jens
I appreciate all the responses.
I’ve been contemplating getting a 54/42 AERO Q ring pair…while knowing you’re partial, I’m still curious as to your thoughts on the pluses and minuses…
Also, I’m doing IM LP in July, comments on performance in the mountains are also appreciated…thanks
