How to cut my Cervelo Steerer tube?
So I know how to cut steerer tubes. but there’s this metal piece in my cervelo, I tried pulling it out but that didnt seem to work. Is it glued in place? do i just need to pull harder?
Any help appreciated.
http://img.villagephotos.com/p/2006-6/1193405/P1020132-1.JPG
look inside, is there a hex nut you can loosen. 8MM probably, my old P3 was like that
Doesnt look like theres any nut inside. I just emailed Cervelo but was hoping to get it cut sooner than later.
http://i179.photobucket.com/albums/w289/plasticorange/P1020162.jpg
http://i179.photobucket.com/albums/w289/plasticorange/P1020165.jpg
Ok,
Take the screw that fits in there, screw it in a little bit, then hit it with a rubber mallet. That should free it up to pull it out
make sure the stem is loose as well. Doesnt look that way in the pic
yup…you need to tap it a bit to make it loosen up.
Thanks guys. Yeah needed to loosen the stem. Tapped it, then it went to the bottom of the steerer tube, then I had to fish it out. If I were going to do it again, I would have placed a big washer under the bolt, so the assembly couldnt have gone very far, and slid down the tube.
You could have just turned the bike upside down… :slight_smile: Glad you got it out. Now just be careful where you cut the steerer tube!
yeah or used the topcap
