How to adjust Adamo TT saddle
I just bought a new Adamo TT saddle and noticed the nose, the front “prongs”, are uneven…one is slightly higher than the other. Looking from the side, you can see the two front support bars are slightly uneven. Is this a defect, or do I just need to try and bend the one support bar to match the other? Thanks.
You could bend them. I had an issue with the bars being too far apart and I zip tied them closer together.
What kind of bike/seat post are you mounting it on? Is it bent like this after you’ve mounted it? I’ve noticed with Quintana Roo bikes (which have an awful clamp design, but I’ve become used to it), you can straighten it out using the set screws on the bottom of the clamp.
Mounting on a 2011 Cervelo P4. I have another post asking how to adjust the clamp…which may be causing this.
Got this with an adamo on my Mtb, there are both side kinda adjustable. On my road or TT it wouldn’t be that easy.
