(I have included my fit coordinates which to me are in Hebrew) The reason I need help is that I am considering the purchase of a Planet X Stealth Pro. I have no idea what size or if I can make that bike fit like my P2. Can you gather this info from what I have given or/??? I have tried looking at Dan’s info, but it makes very little sense to me. I am sort of a hands on guy. Unfortuneately this doesn’t help me in this situation. So I am asking you guys for a little help.
Bike: Cervelo P2SL
Seat Tube Angle: 79 deg
Top Tube Length : 56cm
Saddle: Adamo
Pedals: Look Keo
Crank Length : 172.5mm
Seat Height (A): 76.7cm (14cm back
Seat Set back (B): 1.5 cm
Nose of Saddle to Stem Handle Bar Clamp: 54cm
Seat Angle: .5 deg Nose down
Grip Height: 55.5 cm
Cockpit Length (C): 85cm
Base Bar Angle: 3.3deg
Arm rest to tip of Aero Bar (D): 37.2cm
Base Bar Width: 42cm
Drop from Saddle to Arm Rest (E): 14.4cm
Aero Bar Angle 3.3
Saddle Nose to Back of Arm rest (F) : 48cm
Stem Length 9cm
Arm Rest Width (G): 22cm
Stem Angle: 80 degree
Ummm … those 2 bikes fit VERY different. Why are you thinking of switching? Hopefully not just for “carbon sake.” The Planet X is a surprisingly good bike (just try to find a neg review for one), but only if it FITS you! You must consider this priority #1.
You riding reasonably steep and have a pretty good drop - you would have a hard time replicating your current position on a Stealth (can be done though).
P2SL not P2C. I like the bike, but there are lighter more aero possibilities out there. I was thinking of just getting a P2C since I wouldn’t have to change anything, but it is double the price for the frame. Just thinking.
the planetx is a nice bike, but not more aero than the P2SL
and therefore, not faster.
unless its a TT up mount ventoux, maybe
What is the difference in fit between those 2 bikes? (I’m considerong also a Planet X)…
