How much water inside a wetsuit is too much?
I have an Xterra wetsuit that I believe fits ok but when I stand up after swimming any real distance I have an excess amount of water bulging down my legs. My Aquaman never did this. Is this a problem? More to the point, am I dragging around more weight than I need to? Thanks for any advice…
If you ground, its to much. :wink:
the wetsuit should be your second skin. there should be no big cavities (hope this is the right word)
Yes it is a problem. The perfect situation is when you don’t have any water between your wetsuit and your skin but as this is quite impossible, try to have as less as you can.
Before a race, do this drill. Warm up and 5 minutes before the start get out of the water. Then try to remove as much water as you can pressing with both hands every part of your wetsuit. This will keep the wetsuit tight to your skin and less water will come in next time you get into water.
No it’s not a problem. The reason it’s called a “wetsuit” is because it’s designed to have water inside the suit to keep you warm. That’s why the absorbant textured surface is inside the suit and the smooth surface is outside. “Drysuits” (which is what I guess pale skinny guys in Portugal wear), on the other hand, are designed to have no water between the suit and the skin. And with the water you’re not dragging any extra weight around because the water in your suit is the same density as the water you’re swimming in.
sure? If you carry a tank with water on your back during swimming (the water inside has the same density ;-)) you will be not heavier than without ??? Please tell me more about physics …
You said it all with one word…excess. There will/should always be some inside, hence the name.
Bulges point to the excess. I’d suggest your suit is not well fitted.
It would fall upon deaf ears.
You should have a thin layer of water inside your suit… your body heat warms this up and the neoprene insulates it. What you don’t want is water flowing through the suit or gathering around your thighs like you have. I would suggest a smaller size, or try to snug the neck up a bit. It’s not the suit so much as how it fits you. No suit will fit everyone out there perfectly.
Even after you post, I still think it’s a problem.
wetsuit" is because it’s designed to have water inside the suit to keep you warm. That’s why the absorbant textured surface is inside the suit and the smooth surface is outside
it’s, in fact, designed to keep us warm so it has that absorbant texture inside. BECAUSE of this feature, it’s also made to have water inside but this is a consequence of “first” design, if you understand what I’m trying to say.
so why are that “drystuits” you mention, designed to have no water between the suit and the skin?
A dry suit is designed for more extreme conditions diving. As I said before with a drysuit, no water is admitted into the suit because of the seals at the neck, wrists and ankles. With the entire suit sealed up your body heat is locked in the suit. The drysuit is usually made a little big, allowing enough room for you to wear an undergarment to add extra warmth if needed. It is not used in triathlons.
If you pee and you don’t feel the warmth, there is too much water in your wetsuit.
Give it a try!
