How much training in aerobars?
I am doing a lot of training indoors on a Computrainer. Most of this training has been sitting up with my hands on the pads of the aerobars. Should I be training in the lower position in the aerobars? If so how much of the time? I am so much more comfortable sitting up and can go much longer. But I was thinking while training today that this position isn’t really getting me ready to race. Or is it?
What are you training for?
If you will be spending a lot of time in the aero bars (or should be spending a lot of time in the aerobars), you should spend more time in the aero bars.
I’m guessing you won’t be riding sitting up with your hands on the aerobar pads (which isn’t a good way to ride since your arms probably aren’t flexible and if you do ride on the road this way your body will absorb a lot more of the road vibration than if your arms are bent and relaxed), so riding that way on the trainer isn’t as good as riding how you actually will ride.
As with most things on ST, it depends. When is your first race? What distance? Etc. If your racing IMAZ, then I would think you should be putting time in in aero. I have my road bike on the CT and will ride it until about the end of February when I’ll put my tri bike on. My first race is Eagleman in June so I have plenty of time to get back into position. Then, I will ride my tri bike as much as possible for my long rides during the Summer in prep for MOO. For short rides (<2 hrs), I’l usually just grab my road bike. By ride my tri bike, it’s implicit that I’m in the aero bars and not on the horns or pads.
I also think it depends on how comfortable you are on your tri bike. I am really dialed into my position so although I will still need to adapt to it come March, it’s a position I know works for me so it’s never that hard to get back into it since I’m never questioning it.
My A Race is the USAT AG NAtionals on June 30 (Olympic Distance-40K Bike). I have mostly done sprints so far. This will be my 2nd Olympic. I just got the Computrainer and noticed that it is much harder to pedal in the aerobars than out of them. Also my pedaling efficiency goes down quite a bit when I am in the aero position. I am wondering if this is just from a lack of training in this position. It seems like in the aero position I am using completely different leg muscles and that they are much weaker that the upright position. I race in the aero positon and never noticed this before. I think it was due to it being easier to go faster just as a result of being more aero. Now with no wind resistance, I can see that my “aero muscles” are somewhat weak.
I do 2 or 3 CT sessions per week, almost always interval work. I try to stay on the bars for all of each interval, the only exception being during slower cadence stuff. If I’m sitting up, I feel like I’m cheating. There are many physiological and mechanical variables that change from one position to the other, so might as well train the way you will race.
I don’t know what you mean by “harder”, but your power will decrease when in aero as opposed to when you are sitting up. This is the age-old tension between getting a fit that provides maximum power while aero and preserving your legs for the run. Your power will decrease when aero, but it shouldn’t feel “harder”. Have you been properly fit on your tri bike?
Hmm, I don’t know about that one. I can only speak for myself and my efficiency doesn’t decrease when I go aero. Are you sure you’re positioned properly? If you’re sitting back on the saddle while in the bars, that may explain it since your hips will be closed. I’ve noticed that on the CT, my spinscan numbers vary depending on where I am on the saddle (IOW, how lazy I’m being).
You are. A proper tri bike position will allow you to preserve your hamstrings more than a road position will, thereby allowing you to run off the bike.
It sounds to my non-expert ear that you might want to have someone who’s really good evaluate your fit and position. It also seems that if you are having a large difference in performance numbers, you should ride in the bars much more and allow your body to adapt. If you haven’t been aero over the winter, then your numbers and output will be low as opposed to your “normal” position. If, once you’ve trained in aero for a few months, there are still huge differences, you should go to someone who can evaluate your position properly, although I would do that now so that you are not training and adapting to a poor position or bad fit.
Just my 2 cents.
i try to do about 100 percent. the only time I’m not training on aero bars indoors is possibly recovering after a harder interval or outdoors if I am conering, starting, stopping, or in a group. My goal is to stay in my aerobars at all times to make up for less power than other cyclists.
Dan
www.aiatriathlon.com
Ride your aerobars basically all the time.
Suck it up and go 100%.
The difference your feeling your hip flexors.
Only by doing it (in aero) will you get those muscles to adapt. And they will. And they will best if you suck it up and get into the bars.
It’s something almost everyone who has done trainer workouts has had to deal with.
Also, make sure whatever you have under your front wheel has enough height to get you level.
