How much faster is a Dimpled Zipp Disc VS
a Zipp 404 for a course as short as 15K? I only do really short TT’s and never do any Tri’s. One of the TT I do is mostly uphill too.
The main TT I did last year was the Concord TT in Massachusetts. Most people on here know the one. My best time was 22:21 for 9.8 miles and I averaged around 280 watts. Will the 404 tubular in the rear be that much slower?
The other one is the Fitchburg Longsjo Classic which has a 10K TT course and mostly all uphill. I think the 404 would close the gap even further. What are we talking, 15 seconds savings Max?
Anyone have any idea? I can’t exactly go do a test run with both at the moment!
Thanks for any good advice,
Ryan
All i seen was 15 seconds in your post, is that allot to you? Have you ever lost a placing by that much? I have and it sux, get the DISC!
tfun~
I actually own both. I have lost by less than a second and vice versa. I guess what I am saying is, The Concorde TT is a training race. I may do 2 short TT this coming year where it is actually a race. Is it worth the money to keep the disc? I am on the fence.
The money from the disc will get me into a lot of road races. I love the disc but in reality, If I lose 15 seconds in the TT at Longsjo, I am probably going to lose more or gain it back on the Mountain stage.
Thanks guys,
Ryan
so, let me get this straight.
you want the time savings of a disc VS. 404’s?
as someone wise once said to me, a disc is going to be faster as long as you can control it.
go with the disc, and be happy with the time your put down.
404s are road race wheels, not TT. You want the disc on the back. Sounds like your focus is RR, but if your serious about TT then keep the dic. If your results at Longsjo are important to you, then why give up time in the TT stage. If you don’t have to make it up climbing, then the time you gain climbing can be used to better your placing.
Ric
ttrace
Thanks for the repy. I think you are right, I should just keep it. I need all the help I can get!
I suppose you already have an aero helmet? That would be the first investment you should make before your disc; a good aero helmet should get you down half a minute to a minute on the CBTT.
A disc should be faster, and weight is probably not that much of an issue for the CBTT, since it’s just rolling. Though you should definitely want to keep your Zipp 404s for road races…
  • Guo-Liang
    MIT Cycling Team
