How much effect will losing weight have on run performance?
Say you lose 5 kg (11 lbs)… theoretically how much time will you drop for say a 10k?
I’ve heard 1kgs = 30 seconds in a 10k, but I’ve also heard it’s only 10 seconds, while others have told me it’s closer to 40.
Which is it?
Hard to say, but in my own case I dropped about 1:20 off my stand alone 5-k run after dropping aprox 13 pounds.
The two races where almost exactly one year apart (Thanksgiving Day) and were on the same course under similar conditions.
one second per pound per mile is a formula i have heard is fairly reliable.
I don’t have exact time difference. I an 5’10" 170 when I get to 159 I am faster. My sprint times really go down. Mostly in the run.
I’m about the same weight (around 168 pounds) although a bit taller (5"11)… I want to drop to around 158-160 for the upcoming race season and gibushim so I’d have an ‘easier’ time =P
I don’t think there is any forumla for the relationship between weightloss and performance. There are way way way too many variables to make a solid, mathmatic connection between the two. Terrain, weather, health, overtraining, current fitness, motivation, the level of competition etc all influecne how fast you can run and how well you perform. It is too simplistic to say “If I loose X pounds, I’ll be Y faster.”
I would say there is a connection - the less dead weight you have the faster you’ll be - but it is too complicated a relationship for a formula.
I’m just asking because I’ve been feeling sluggish all season, and I’m wondering if it could be because I put on a couple of pounds in the off-season that I’ve yet to lose?
It depends on how you lost the weight, training or dieting. But why look for a theroretical answer – strap on 5 kg and give it a go. Even thinking about this might give you a little extra motivation for losing it.
On top of all that, dieting and lack of carbs/nutrition could put a damper on your performance.
I’m no expert and you can keep all the variables but when I get around 195 and under ( from 205 most of the year )
I feel like I could run thru a wall and keep going. Just my .02.
Time for the obligatory Daniels’ quote:
“…there’s no doubt that the loss of nonessential body fat results in better race performances, even in the absence of improved fitness. It’s hard to tell, however, how much of improved running performance can be traced to a leaner frame rather than the fact that quality training can be carried out more effectively with a slimmer body.”
If I was you, I’d just try to run alot more to lose the weight. That way, you’re covered on both ends.
It all depends where you are at right now.If you do not have any excess weight on your body and in prime running shape losing weight might even effect you negatively.
The answer is simpler than it might appear, some French guys have put the data together.
Each colored line is your current weight, find your current time and it will show how many minutes you will drop.
Look at the graphs at the bottom of this page, http://www.vo2max.com.fr/physio_poids.html
As other posters have mentioned, look at it from an effect angle and not a cause…
Your approach is sort of like asking how do more ice cream sales make the weather to get hotter.
I heard “X% drop in body weight will give an X% increase in running speed, all other things being equal.”
This formula holds up well for me when applied to larger values of X. The first time I tried the formula, I looked at my heart rate for 9:00/mile when I weight 180lbs, vs. 8:00/mile when I weighed 160lbs. It turns out my HR was the same both times, which fits the formula exactly. For small changes in weight, or for very fast/slow speeds, “other issues” were hard to isolate.
It isn’t an exact science, but my personal data support the “X% weight loss / X% speed increase” rule of thumb.
do you train to lose weight, if you did the traning alone is going to help you hit the PB, so often when you hear how someone lost weight and suddenly goes faster you have question their reasoning. Also as the Daniels alluded to the fact that the less weight you carry the easier it is on your body, impacting recovery and thus training volume. Another view point often never asked is - how did a person get to a particular weight be it 150lbs or 300lbs to then start losing the weight and coincidentally start going faster. They might not have been active in the first place.
Kevin, that’s a great link-thanks!
In my experience with the folks I have worked with, assuming the weight loss is no more than 1 pound per week, a 0.62% increase in running speed per pound lost is fairly accurate. Related thoughts: weight loss
-Jesse
i’ve lost about 5 pounds since last winter/spring. in a recent 5 mile race i took off 6-7 minutes from last year’s time, as well as 21 minutes from a 1/2 marathon. granted–i have stopped drinking alcohol (since August 19th, 2006) and have been running at least 2 more days a week…so it is probably the cumulation of all those things that equates to the improvement.
IMO, it is important to not only manage weight, but also keep up consistency, build the right base, etc. nothing can substitute for mileage.
