How low is too low for aerobar setup?
In response to Slowman’s article, I am wondering how low “too low” would be. I recently installed a Ritchey adjustable and while I have had no problems as of yet, I’d rather avoid them all together up front.
Jimmy
Not sure what you mean here.
Certainly, getting the right aero fit is really important. What I thought was pretty good for TT last year (and it was by a FISTer) turned out to actually be not so good upon further review.
You’ll probably know if you’re too low. If you train by power, you’ll have a tough time reaching the same power levels you do on your road position. Oh, and it won’t be comfy!
I’m still figuring this out also. I just removed all the spacers from my P3 last night and dropped the front end. It felt great. I need to do some tweaking on the seat height, seat fore/aft positioning, stem length, and aerobar setup. I’m going to hopefully go to a zero rise stem soon and really slam that sucker now that my gut is out of the way.
Low is overrated. Look at the “Germans”. Zack, Stadler, Al Sultan, Hellriegel, have never ridden super low and all have amazing bike splits. You don’t want to be positioned like a sail, but you want to ride a position where you can “stay aero” as much as possible into headwinds and false flats. I see tons of guys “sitting up” when they hit a stiff headwind or a rise instead of staying aero. This defeats the purpose of being low.
You also want to see how fast you can run off the bike. If you go super low, your hip flexors, hamstring and lower back have to do tons of extra work and you will take more time to get your running legs. The goal is not to have the fastest bike split, but optimize bike+run split to get the lowest achieveable combined time.
Jimmy
Check out Kraig Willet’s website: www.biketechreview.com.
Kraig has started a collection of body and bike measurements, along with associated aero data, so that we can start to learn from each other. I thought my bars were low at 18cm down from the saddle. The really slippery folks are riding at 20 and more. I’m picking up a new stem tomorrow so I can try it at 21cm down.
http://www.biketechreview.com/performance/position_table.htm
Look at some of the photos on Kraig’s site, then take photos of yourself and compare. Finally, expiriment and see what works. I found that I could maintain power, stamina and run legs in a much lower position than I had thought. Lots of other good tips on aero positioning on there.
Steve Larsen rode super low and had amazing bike splits. As does Bjorn A. Tim D and Peter R ride low (meaning: flat backs) and have amazing run splits, and win races. Natascha, too.
Stadler finally went to the wind tunnel this summer in San Diego. He rode at Kona lower than in his past years based on what he learned.
Finally – and most importantly – none of us are these guys. If they can ride 4:30 sitting up into the wind, then have at it. I, for one, plan to punch as small a hole in the wind as I can. So far, I find no limits to my ability to stay down in the bars and run off the bike. I recently set a half marathon PR running off a minus 18.5cm bar height.
Aerodynamics is *underrated, *IMO. Not aerodynamic gear and bikes – but aerodynamic body position.
This is only the case if you close down the torso by not moving the saddle forward. Roughly speaking, having the saddle 5cm back of the bb with the bars 8cm down is an identical set of joint angles to riding with the saddle 0cm to the bb, and the bars 12cm down. Muscle activation is the same, but the second one is much faster. Only UCI-rule-followers need to worry about squeezing down the torso. We draft-free triathletes are free to make our bikes fit properly.
You are correct that it is closing down the hip angle that is ain issue. Natasha, I would argue is not super low, rather in an optimal all purpose aero position. I agree Reid is low and runs fast which seems to be an exception. Most guys who go too low close down that hip angle and end up running slower. And you can’t just keep jacking the seat forward to facilitate aero. There is a relationship between your relative saddle position over your BB and pedaling in circles and maximum power application. Go too far forward and you lose some power too, so there is a tradeoff.
when your knees hit your chin you have gone too far… …or you have to switch your name to Keith Pillers.
jd
Quite true. After a while, it takes too much effort to hold up the torso and the effort begins to detract from pedaling. You end up with an upside-down recumbent.
My main point is that people should try it. If it doesn’t work, move back. Use photos of yourself because it’s really hard to know how you’re set up if you don’t. I thought I was low until I took pictures. I was sitting practically straight up. Now that I’ve been riding low for a year, it doesn’t feel at all low anymore. I also made a giant right angle out of yardsticks to check my foot-to-hip-to-shoulder angle (per slowman’s fit articles). My wife holds it to check the angles any time I make position changes. I am going to drop to 2cm (at the shoulders) more acute than 90 degrees, using Dan’s points of reference, as my next change and see if it works. That will take my bars down to about 21cm below the saddle (saddle nose at 2.5cm in front of bb). I’ll ride it a while with the Powertap and see what I learn about power output, stamina, running and CdA.
Good points.
Here’s a few more:
  1. There is the math and geometry of good bike position and then there is the real world.
  2. The first thing to find is that sweet spot relative to the bottom bracket where max power transfer and optimal comfort come together. All things revolve around this point.
  3. You can get professionally fitted, but I still find that I need to fiddle with things a bit at home on the trainer( a great place to figure these things out) and out on the road( I often carry a set of allan keys and make small changes to see what happens).
  4. As to the position of the pros, they should only be a rough guideline. Simple reason, they have all day to ride in these positions and get used to them. We only have a few hours each week.
Fleck
