I’m planning on bleeding my P5’s brakes soon (mainly so I can finally get the damned front brake cover to fit properly!). It looks like the bleed kit doesn’t come with much fluid.
Is it actually enough for both brakes?
If not, can I reuse the fluid currently in the brakes?
Also, it looks like the “Magura Blood” is just mineral oil dyed blue… Is that true?
If it is indeed just mineral oil, then best practice would be to alternate with un-dyed every other flush. Keep pumping it out till the color changes. Old fluid is a little darker, but blue to red will be more obvious.
The 100 mL bottle is enough to fully flush a few bikes. Watch a bunch of videos, take your time, do the front first (less turns, shorter hose) and you’ll do great.
What is the standard service interval on magura’s road brakes? (Of course, “as needed” is the right answer, but in practice…is it every season? More? Less?)
My experience is on cross and mountain bikes which is way different in many ways. I do a quick bleed a couple times a year and a flush once.
I assume that thick padded brakes, used lightly in good weather, perhaps primarily during races…would last a LOT longer.
