…recable a bike? I have read many posts about STers cabling their bikes and would like to get my hands dirty myself. I guess what I am looking for is some info on what I am getting myself into and also some tips you may have learned along the way. I plan on using Zinn and the Art of Roadbike Maintenance and maybe the Park tool website if need be. Are there any products I should use or stay away from? Thanks in advance ; )
just need cables and cable cutters.
just don’t cut the cables to short. You can always go back and cut them.
O
this is actually really easy. Just make sure you have a dremel with a cutting wheel or a REALLY good pair of side cutters. i don’t think you need the special Park cable cutters. Buy more cable and housing than you think you need, measure twice, cut long and recut to proper length.
Give yourself the better part of the afternoon if this is your first time.
Not too hard, you will need the correct tools to cut the cables. Don’t get cheap ones as you will be buying the better ones later.
Make sure the cables run through the housing smoothy and there are not sharp kinks in the housings.
Learning the adjustments may take a little bit of time but with practice you can get it right. The end stops will have allready been adjusted if you are re cabling a bike but you should learn how to adjust them anyway. I wouldn’t learn how to do it the day before a race.
Give youself a day to learn how to do it.
jaretj
Duh, thanks Ben
and there are now sharp kinks in the housings
You might want to edit that line ![]()
The short answer is: it is not hard.
Last summer I converted my mtb to an all-rounder and fumbled w/ the idea of taking it to a shop. Instead, I ordered cables and learnd how to do it myself by trial & error. Now the cables work flawlessly and the arcs looks so smooth and cool.
I took what I learned and re-cabled my roadbike this winter. Now THOSE cables are also in nice smooth arcs…and I am pleased. In fact, it sorta makes me want to go out and recable other people’s bikes now…just for the fun and beauty of it all.
caveat: Neither bike had internal routing. I don’t know what sort of hurdles you’d hit when dealing with that.
I second this. A Dremel tool with a cutoff wheel works great on cable housings.
(You probably should have a Dremel tool and cutoff wheels anyway…it’s one of those tools that you’ll never figger out how you lived without after you buy one.)
slightlyoff topic but it is the Dremmel tool really worth having. Can you buy it with all the attachments? or most useful attachments?
slightlyoff topic but it is the Dremmel tool really worth having. Absolutely, I was amazed at all the little nagging jobs it took care of, that I wasn’t even thinking about when I bought the tool for something else.
Can you buy it with all the attachments? Yes, find a Home Depot. They have nice kits which includes the most common accessories. The kits are also far cheaper than buying the components individually.
or most useful attachments? Again, yes.
Thanks all for the advice. Monday is my next offday so it sounds like a good project to tackle than. On the side topic, a Dremel tool is like an electronic version of duct tape, it can basically do everything. I bought one a while back and it came with something like a hundred attachments. You just can’t go wrong with the thing.
As others have said, yeah, and I think so. I’ve used mine for cutting toilet bolts, steel bars, plastic, copper pipe, and drywall. I’ve used it to remove grout and grind glass. I deburred a pipe last weekend. The little router base is kinda cool when you need a very small router (I have two other real routers). You can polish jewelry/bumpers/the bell on your handlebars with it. I’ve done limited sharpening with it.
They are very versatile.
Make sure you get one that is variable speed…they may all be anymore. Mine’s corded–maybe someone will weigh in yea or nea on cordless versus corded.
*Can you buy it with all the attachments? or most useful attachments? *
It’s unlikely that you want all the attachments. Make sure you get the spindle that holds the abrasive cutting/cutoff wheels (google it). Those little bad mother(shutyomouth)s will cut almost anything–WARNING–when using the cutting wheels, ALWAYS wear these-tink,tink safety glasses. The wheels are very thin, and break rather easily, and pieces fly wherever they fly when they do (mostly when they go sideways in the cut–this makes them shatter). This is the tool that you are being advised to use to cut cable sheathing.
“Most useful” is context dependent…the set that is most useful for general handyman work will not be the same set that is most useful for a leaded glass artist, or an intarsia artist, or a power carver.
edited to add: Someone was asking recently how to cut a carbon seatpost. I’ve never done that, but I’d bet dollars to dog turds that a cutoff wheel in a dremel tool is the best way, for someone who doesn’t have proper carbon tools (diamond wetsaw, or whatever the real right tool is), anyway.
