How fast can YOU change a flat?
??? which are you changing, tubbie or clincher, and how fast can you do it during a race?
Hmm, never timed myself and from the many unfortunate times I’ve had to on training rides, I’m not very fast (if I try to be, I make mistakes). Never had a flat during a race, so I guess I’m lucky.
I can say I race on tubulars and train on clinchers as I can change a tubular in about 1/2 the time I can do a clincher. I use Tufo tape & Tufo tires and with a single tire lever can get the tubular off. I’ve started using Tufo tubular/clincher tires on my training wheels for a similar reason - easy of changing flats. To me, they perform OK and unfortunately are disposable and not too cheap, but they make a super spare tire as you don’t have to deal with pinch flats or stuff like that with the tube, just slightly more difficult than a tubular. Guess I could always change it back when I get home (to a normal tube & tire).
-Chris
Clincher takes me about 7-8 minutes, not very fast, but I really go through a process to make sure the tube is seated properly not pinched etc. I can do it faster but no doubt will risk blowing it again…CO2 helps…rear wheel takes a minute longer, always screwing with the derailleur…never had flats in races, but plenty in training…I bought race wheels and will be putting more puncture proof tires on my training wheels…
I changed a tube in a clincher during a race in under 4 minutes.
jaretj
hahaha thank you, finally someone said this. i have been thinking that in anything under a half this is the case, some keep arguing with me.glad to see somone agrees
A couple of years ago we held a contest at a tri club meeting and one guy was able to fix a flat in under 2 minutes. That included taking the wheel off the bike, removing the tube, feeling the inside of the tire for stickers or other things, putting a new tube in, putting the wheel back on the bike and inflating. This was done with clinchers and a CO2 inflator. It was also the front tire which is a bit faster. Start to finish in under 2 minutes.
Of course this was inside a meeting room instead of on the side of a road in blazing heat and windy conditions.
I can change a clincher flat in less than 4 minutes, as long as no one is watching. Being watched increases my time, much more so if it is a guy I want to impress. :slight_smile:
My one race experience with a flat was at mile 90 in IMLP this summer, Got my rear wheel off and the tire off, up drove 4 guys on 2 quads to help out. So I ate a gu, drank some water and watched. Unfortunately the first tube blew so they had to change it again. seemed to take foreverrrrrrrrrrrr…
another liars thread !!
I love it
dirt
Clincher - about 5 mins when I’m hussling with friends waiting on a training ride. In a race - doesn’t matter as that 5 mins puts me out in anything under a 1/2 IM. Road racing - forget it. Only flatted on a tubular once (IM FL): rode it flat 2 miles x 2 until I found the Inside Out neutral support van and had him change it as I figured he would be much faster. He was - did it in about 2-3 mins.
I am an expert flat changer. It takes me a long time anyway.
10 years ago I flatted a front sew-up just as we came up to a light that was turning red. The lightly glued spare was in my back pocket and the stupid fork tabs on the frame ends had been filed off so the wheel was out in a second. A buddy had his pump ready to blow it up as soon as the spare was on, the flat was fixed and I set off with the group as the light went green, it was just over a minute, but everything went perfectly. With far too much glue on a rear sew-up I lost over 5 mins in IMLP '05, which taught a valuable lesson.
Can somebody explain something to me about why some folk take so long to change clincher flats…? I often see experienced cyclists pull the tyre off the rim, then search, invariably in vain, for the bit of glass or thorn that caused the flat. Why don’t they keep the tyre hooked on the rim, remove the bad tube, and blow it up to about 20 PSI. When you hear the air coming out you can hold the bad tube against the tyre and can see exactly where on the tyre you need to look for the guilty piece of road debris. Surely this would save a couple of minutes, and would give you much greater likelihood of finding the debris. Admittedly if you only have a CO2 you might not have enough spare “air”, but I don’t know why more folk don’t do this when they have the air.
Neither tubbie nor clincher matters in the time. Its how far I am from home that matters. This determines the time it takes my wife to bring me my spare wheels : )
Somewhere between 8 and 40 minutes: I am a complete uncoordinated spastic, which is why I do tri’s instead of sports which require dexterity, skill and finesse …
I got a flat in my very first tri - Gulf Coast a couple of years ago. It happened at mile 10, right in front of a McDonald’s on the way out of town. I didn’t look at my watch, but it probably took around 5 or 7 minutes…one of the locals walked up and watched…he asked if I was running a marathon!
I’m wondering if anyone’s had success with the pressurized sealants. I’ve been carrying one around with me (along w/spare tubes &CO2s) for half a year but haven’t had to try it. Clinchers take about 5 minutes.
Clincher; wheel already off the bike; time from before taking old tire off to time of inflation with a pump (90 psi); timed event at IMUSA a couple years ago (put on by local bike shop):
32 seconds
Fastest on road change was <2min from stop to back on bike (with co2 cartridge clincher)
Stephen J
Not sure… I don’t know how to do it… I need to learn!
sounds like a good idea.
i usually find the glass or whatever it is, though. the thing is, if i’m changing out the tube, i’m not going to stop checking for glass/tacks/etc once i find something; you gotta go all the way around the tire at least once if not twice.
I have timed myself.
Normally, 14 minutes for the front tire. That’s if I’m more concerned with examining the wheel and tire for something that caused the flat in the first place. My fastest was 9 minutes. The rear tire takes an extra minute or two. Luckily, I’ve never flatted during a race… yet.
Well, back in my mechanic days for shits and grins we would time each other with clinchers.
My best was just under two minutes. But that was not with checking the rim and/or tire for what would have caused the flat and an air compressor in the shop. I’ve never timed any of my tubular changes.
If I flat on the road, I’ll usually take my time about it to make sure I find what casued the flat in the first place and check the whole tire. It’s not worth being fast if you end up flatting again 5 minutes later.
