How fast can 1 go in IM under 300 cal/hr on bike?
I hear you on the burps. Man I had a stomach full of air in my last 1500m swim and I had to tread water to get it out. It had to raise up. Lying flat in the water does not do it for me. You could hear the echo on land. Sound travels quickly across water!!
Thank you all for the great response.
I didn’t name the products because I didn’t want this to become a my stuff is great and XX is crap. I was using Hammer Perpetuim. This year I mixed that 50/50 with Heed. 3 scoops of each into a 24 oz bottle. 2 bottles of mix. I had a 24oz bta of water and probably another 24 oz of water and a small amount of Perform. Total fluid of around 100 oz for the 5:29 bike split. Plus 2 Hammer bars. One starting the stick (mile 15) and the other coming back into Verona (mile 60ish). I took in almost nothing for the first 15 minutes. Being concerned about the full stomach thing, I had been training trying to reduce my overall fluid intake, not calories. This seemed to work ok. I had a little fullness running off a 5 hr training ride. During the race, I just couldn’t bring myself, while being thirsty, to limit my water intake. I did have 4 salt stick capsules on the bike also. This year, even with prehydrating the day before and the morning of, I peed once in the last leg of the swim, but had to force, really force, myself to pee on the bike at about mile 105.
I didn’t pee until mile 105 ish…might be the same long downhill on the stick. I drank about 130oz of fluids in 5:08. But I’m 167lbs and seem to sweat a descent rate even in cool weather.
Not sure of your height/weight but for one athlete, small female around 122lbs 5’5
Bike:
500 mg sodium/hour (all sources)
350 cal/hour all sources mostly carbo pro, some sharkies, some gel
About 8 bottles all sources, emptied once on the swim X2 on the bike
(about 4.8L) or 150 ounces
Run:
Gel @ 25 min… After 4 gels only coke and a bit of perform/water
Run totals about 750 cal or so… About 200-220/hour.
Hot day in Whistler, for you 100 oz is about 2.9L, about what she would have in a half.
I would say, ditch the solid food, ditch perpetuem (go 100%carbs) drink more and…most importantly prove pacing and nutrition in training.
Maurice
Thanks for the reply.
This year, and last years race weight was 171 lbs and I am 5’-9".
I am VERY open to changing everything. I train too hard to not have the results I want and believe I am capable of. I think I will have much better race results once I figure this nutrition thing out.
I guess I should add these points.
I don’t think I have ever experienced a bonking. I have hurt. I am ok with being in pain, but I’ve never felt like I was just drained and couldn’t continue.
During training, I really only mix anything for a ride of 3 hours or longer and only have water, maybe a fizz tab, for a long run of 18 miles (7:45 ave pace).
the sloshing is likely due to going too hard for your ability and/or taking food before water.
I understand the pacing question, I don’t understand the taking food before water thing.
Some might argue for less hydration, IE Noakes… Who is a pretty smart guy and in the past has posted on here advocates drink to thirst etc.
IMO that is not the best strategy, or I would say I have had different experiences. Do a weigh in pre/post long ride/run. For me the loss rate on a hot day is about 2.2L per hour run and about 1.5L for the bike sodium loss rates IIRC are about 1000mg per L. Aim to pee about once every 2-3 hours. Just like a normal work day.
Calories are based on out put/duration and fitness… Alhough you need hydration to help emptying.
FWIW I am about 425-450 bike 275-300 run cal
On a hot day 12 bottles on the bike…on a cool day 7-9
800mg sodium.
Maurice
FWIT I am about 425-450 bike 275-300 run cal
800mg sodium.
Maurice
I haven’t ever done the pre/post workout weighing. I probably should. I think I would be considered a fairly heavy sweater. 12 bottles on the bike during a hot day just blows me away, even 7-9 on a cool day=OMG, :slight_smile:
If you have enough water in your stomach it makes the food pass into your intestines easier, where it absorbed. if you eat food first and let it sit in your stomach without water, bad things happen.
[quote SallyShortyPnts
If you continue using UCan for training and adjust your eating to higher healthy fat and lower carbs (especially the sugary gels), you’ll find that you are what you eat. In other words, if you want to burn fat, then eat it!
That’s not true at all. During exercise, insulin response in inhibited so the idea that you have insulin spikes in reaction to sugar is false. Even the UCAN “proof” shows this. The main benefit of consuming UCAN is that you can take in a lot at once, and absorption is slowed anyway so you get a good, constant release of fuel. You would get the same result from taking in small amounts of maltodextrin more frequently. Eating fat during exercise is of little value, since your body has more than enough fat reserves to power you through multiple ironmans without eating any fat at all. On the other hand, glycogen reserves are limited. So if you are going to take in xyz grams of food, the optimal from a performance point of view is to take in carbohydrate. If eating fat makes you feel nicer, then by all means eat it, but from a performance perspective there is little point. If you are already in a good fat burning state, even taking in pure sugar has almost no effect on how much fat is being used for energy as a % of total energy utilization. Of course every individual varies - I’m talking predominantly about well-trained endurance athletes, racing at a moderate intensity such as ironman (let’s say 75%-80% FTP on the bike)
I’ll add to the anec-data… nutrition for my training has been a high-fat diet, then Gen Ucan during exercise.
Pre-workout (30+ mins) = 220 cal from 2 scoops of the choc-protein mix
Workout: 180 cal per hour from 2 scoops of plain (mixed very thick with Trader Joes unsweetened coconut milk)
My race plan is to follow this, and I almost got to try it at IMLT. Instead, I’ll be lining up at the start of IM Barcelona October 5. It’ll be my first IM.
Nutrition data points are always quite personal, and some context for what works for someone else is helpful… I’m not “very-low” carb any more, just less than most (especially endurance athletes). Prior to endurance training for IM, I was in Nutritional Ketosis (very low carb) for 6 months and consider myself to be “fat adapted”. I’ve followed what was the Mark Allen Online 20 week program (now Smart Triathlon Training), which is using Maffetone heart rate with the Allen/Vargas blocks of volume/strength/interval progression. (They don’t endorse my nutrition approach, but haven’t condemned it either!) Happy to discuss more specifics and results with anyone that’s interested.
Rob, I (any many others) have been skeptical about the carb<–>insulin<–>fat burn relationship during performance, but it’s hard to argue with the results of this guy…
HOW TO WIN THE IRONMAN ON LCHF
Bevan McKinnon, aged 43, just smashed the age group field at Ironman NZ. He set a personal best of 9.00.59.
We feel that the whole Kreb’s (fuel) cycle in the body was spinning fast enough and fuel utilisation was high enough that insulin wasn’t being secreted in massive amounts to dial down fat burning and promote glycogen only fuel use.
The whole thing is a great read!
I’m not against LCHF in terms of day to day eating, but the mistake people make is continuing to eat fat during the race. In that race, I believe Bevan fueled high carb.
That’s the key thing. That’s also how Sami Inkinen races (he lives LCHF, races high carb)
Here is a quote from that IMNZ report of Bevan’s: "Here’s the big change made. The race fuel wasn’t fat, it was 20 gels and 1.5 bottles of coke on the bike leg. "
I’ve measured the same thing with metabolic testing (I have a metabolic cart). Several days of LCHF, but then fueling with high carb (500 calories of maltodextrin/fructose mix per hour) during a race simulation on the trainer (80-90% FTP), and fat burning stayed in the same ratio as at the beginning of the simulation (carb depleted, fasted, with high fat meal 2 hours prior).
May I’ve seen on the LCHF band wagon continue eating fat on race day which I think is not smart. I seem to remember that Bevan guy tried to race another IM only eating nuts and he totally fell apart.
The winner of im Maryland did it on 100 cals/hr
Interview details on endurance planet podcast
In 2013, I did my first 2 70.3’s. I went 4:55 and 4:44. I did those with a 270 calories per hour on the bike. I had absolutely no problems with GI on the runs.
IMWI 2013 comes around. I upped my cals/hr for the bike to 318. I had faded off the end of the bike a fair amount. It could have been fitness. The first half of the run was had with a somewhat full stomach. Full enough to be uncomfortable. Got better around mile 5. It never really emptied, just became tolerable, ending with a 10:55.
2014 rolls around, 70.3 mid summer. 360 cals/hr on the bike. Terrible day. Bad fade at end of bike and torturous run. Stomach sooo full, I was thinking seriously about just puking to empty it. Still managed a 4:5x.
IMWI 2014. Trying to limit the water intake on the bike to combat the fullness issues starting the run. I cant do it. I can’t not drink the water when I’m thirsty knowing the run is still ahead of me. I take in 350 cals/hr. Fade a bit in the 4-5 hr mark on the bike. The first 7 miles of the run were very painful. My intent was to not walk any of the run. That went out the window if I had any desire to finish this race. I walked every up hill for the first 5 miles to try to calm my incredibly full stomach. This, in my mind, was a completely defensive move. My stomach was soo full. No room to even slosh. I wound up 10:44.
The subject line asks the question. I know everyone body is different. What I haven’t seen yet though is someone’s RR that went sub 10 claiming to have only taken in under 300 cals/hr on the bike. Some are close to 450!!
Please help me ST community.
I suffer from stitch and was advised not or eat or drink for the first and last hour of the bike or the first hour if the run. The middle three hours of the bike I took ~3 carbo shots/hr. After the 1st hour of running I drank coke at each aid station. 73kg/183cm - really struggled to keep moving last half of the run. ~9:45. Have not used that nutrition plan since!
Sounds to me if your fading your not fit enough for that pace. At a relatively higher intensity you’ll struggle ECM more to eat / drink. I’d look at changing your program to get fitter/ slow down and eat/drink less.
