I have just gotten my polar power meter all set up. Amazingly, I didn’t have too many problems, and only one ride where I had to keep getting off to adjust the unit (the power unit, that is). Since it’s supposed to snow again tomorrow, I won’t be outside anytime soon to look at power numbers on the road. Today was my first ride with good data.
So how does being on the trainer effect the numbers? I have heard some say they get very inconsistent power numbers indoors, but mine are perfectly consistent. However, I am hesitant to get excited about the fact that today I averaged 253 watts for 2 hours with my average HR below 140. If those numbers are true, then I think I’m going to have a good season. This is the first time I’ve used power, so I have no comparison to past performances. Does being on the trainer inflate the numbers?
what sort of time can you do for a 40km Time Trial? I did some tests with my PowerTap SL on Saturday and did a 20km TT and then an 8km TT and averaged 260 watts for 32:20 for the 20km TT (not flat and turnaround on the road with traffic) and 271 watts for 12mins on the 8km TT…does this help?
Going 253 watts on a trainer for 2 hours seems too high…so you must be really strong cyclist…either that or wattage was wrong…
or the original posters mass is significantly greater than yours or is much fitter or the power is wrong on the polar…
you really need to scale the power to measure of mass to get a more effective number to work with. At RST we use power/mass^0.67. This helps deal with different sized athletes. If the OP is 90 kg and you have a mass of 60 kg then you may be faster even though your power maybe less. Obviously, for flat type riding a measure of CdA would be better but few people have access to accurate numbers for this and mass^0.67 is a good alternative. You can get an idea of power to mass^0.67 for MAP data by going here http://cyclecoach.com/downloadPages?download=Calculate_your_MAP_zones&ext=.htm
Wow - that seems high - but without knowing how strong you are that doesn’t really give much information. That could be a moderate number for an elite, but a great number for a regular AG.
I’m a solid cyclist (but not great) and at an HR of 140 I average between 210 & 220 watts. I’m 33 and ride ~ 5:30 for an IM course. So if you are faster then me holding 255 for 2 hours at 140 could be a sign that you are in great shape this early in the season.
I get pretty standard numbers indoors or out. If I do a short TT I get pretty much the same average power.
Maybe being on your trainer is similar to hill climbing…usually people hold a higher wattage on uphills, don’t they? It seems like many trainers have a somewhat similar lack of momentum-effect as riding uphill, so, it would follow that somewhat higher wattage could be seen on your trainer, wouldn’t it? Just a possibility…I’m not claiming to know the answer.
These are all impressive power numbers…does anyone have any receommendations to help someone get to these levels…I just got a Computrainer and I am no where near these levels…thanks.
While it’s been said that the Polar Power Kit is unreliable on trainers, I have also heard that it is mostly from cross gearing, and that many people get very good numbers compared to other power meters. Find a friend with a Computrainer and do a quick comparison, and also make sure you try to keep as straight a chainline as possible.
The Polar Power meter is just not reliably accurate enough from a scientific standpoint. Training by power is after all a scientific approach. Sorry to tell you, but even if one was right on, switch gears or cadence and it becomes all garbage data.
“I averaged 253 watts for 2 hours with my average HR below 140”
I figure an increase of 10bpm HR = about 20 watts, so you should be able to do about 320w at 170 bpm. This means you should be able to do a 53-55min 40k given avg body size and aerodynamics.
Well, that’s the point. Check the gears you use most often to see what effect, if any, it has on reported power.
What you don’t want to do is ‘test’ it by checking every possible gear combination (cross gearing) and then thinking that the Polar is a horrible power meter.
Ok, so what ‘scientific’ testing has been done to show that the PPK produces ‘all garbage data’?
I don’t have one, but I believe Kraig Willits on bike testing showed very good correlation between the Polar and other power meters. Not definitive for sure, but I think it points away from ‘garbage’.
I assume you do all your testing in a lab on a Velotron or something similar? Right?
You’re right, for you, you’d certainly want to check those combinations, and the PPK might not be the right power meter for you. Personally, I avoid using the 2 biggest/smallest cogs when in the opposite ring.
