I’m considering these two models, any thoughts on how they compare?
The slice is a bit less aero but still decent. However, the skice has a higher stack, so if you need spacers on a p2 the slice may be the more aero bike for you if you can ride it sans spacers.
You should be able to win any tri on either bike.
Completely different fit on those two bikes
P2 is long and low, slice is short.
Can’t comment on the P2 but I put a few thousand miles on 2 P3C’s and I now ride a Slice. The Cervelo was too long for me. I needed a shorter reach so the Dale works. As for ride, Cervelo is stiffer. That’s not a bad thing. I really liked the power transfer of the Cervelo. The Slice seems to absorb rough pavement a little better.
Well Chrissie Wellington has won Kona on both of them.
x2.
Did you get fit on both? Buy the one that fits. My spidey sense says you are buying on marketing, not utility. Bad thing to do for a tri bike.
