How does my position look?
I am a mtb racer who decided to check out triathlons. Unfortunately, my shop has no idea on how to fit a tri bike. I have looked at a bunch of pictures on this site and think I am pretty close. What do you think? Should I change anything?
Thanks for the advice.
Jeff
http://i12.tinypic.com/4fts6eh.jpg
As always, the seat is definitely too high…maybe bordering on something that could cause injuries. Other than that I like it a lot for a new-comer.
Chris
Agreed – seat looks high. YOu might also want to slide the seat back and sit farther forward on it. Overall pretty close, to my semi-trained eye.
Paging Dr Coggan! There it is again.
Even to my non expert eye your seat is too high.
Your seat is too high.
Boy, you’ve got wood.
Chris
Why would you want to slide your seat back and sit farther forward on the saddle? Won’t that leave him sitting on the nose? And if that is what you’re recommending why would you want to sit on the nose versus the back of the saddle given that the he would still be riding at the same angle as before?
I said “might”. I do this, and I know a lot of others do as well. Depends on length of ride, of course (6 hours like that is torture). But for shorter course stuff, it helps with pelvic rotation and flat back. Essentially doing a “hang two” off the front of the saddle.
Exactly what I was thinking. I do not agree with sitting on the nose. I can push more watts with the support of the back of the saddle. Oh…and before anyone else says it…I moved my seat down a full cm.
That’s a start but I’ll bet you can stand to go down more than 1cm from where you are in this picture. I’m no expert but I bet 2-3 is closer.
I agree. That seat is frickin’ high.
Ok…moved it down another cm. Now I am 2 cm lower than the pic.
Thanks,
Jeff
Ive got some good reasons…think POWER:
http://photos-743.ak.facebook.com/ip002/v55/9/48/20700413/n20700413_32149743_7327.jpg
http://www.digitaltriathlon.com/admin/resources/images/8185.jpg
http://www.digitaltriathlon.com/admin/resources/images/9126.jpg
I guess my main question is why would he need to physically slide his seat back to ride on the nose? If we wants to ride on the nose just slide he could just slide his butt forward from where it is now. If he moves his seat back he’ll be riding at a more slack angle if he does ever want to ride back on the saddle.
Maybe every city has a Bicycle Alley, but are you from Worcester?
-Brian
It seems pretty forward now…so if he goes to the tip now it may put him too steep…Its actually not that uncomfortable to do all your riding on the tip though, so even if he was no longer able to sit on all of the seat b/c of it being too far back, he could be alright.
Yes…I am from Worcester.
Jeff
That makes sense.
So, if I slide my seat back and sit farther out on the nose, I would be in the same position relative to the bb. How does that generate more power? According to the chart on this site I am at 79 in the picture. I would guess that the athletes in the pics you posted are running slacker angles and moving out on the nose for a steeper position. My position is already pretty steep in the picture.
Jeff
Sorry, but being in a particular position on the seat that is the same “relative position” from the BB will have no impact on power (unless you are REALLY far back and the seat is actually imparing your thigh movements).
However, I personally have found that I can maintain a significantly higher cadence while nose-riding, which in my case translates to a being able to hold a given speed over a longer distance. Of course, I’m 130lbs and will never see 280 watts of average power (nor do I need to), so cadence is my key to riding fast.
Chris
