Well, all the experts notwithstanding, I’ve been TTing on both a 700c bike and a 650c bike for the last four years.
My fastest TT ever produced a track record for my age group at the Lowes Motor Speedway series (29.7 mph) and that was on 650c wheels with butyl tubes. That’s not a flat course, but it’s pretty smooth and, on a smooth course, 650c wheels can be damned fast.
I’ve won my state TT (age group) each of the last three years. The course is very rough chip and seal (we call it Carolina Pave) and, though there aren’t any large hills, it’s never really flat, either. In '08 I ran my 700c bike and took nearly a minute off of my best previous time. Could be all kinds of variables, but the larger wheels seem to roll better on the rougher surface (plus I was using a Hed C2 wheel with only 90 psi … smoooooooooooth).
Generally, a 650c bike will have a shorter wheel base and this will make for a rougher ride if the pavement is bad. (Think about how bouncy a jeep is … short wheel base.) It will also make for quicker handling. I do a few races that have very tight turnarounds. They’re much easier to handle on the 650c bike. Cut your wheel hard on a small bike with 700c wheels and you’re likely to hit your foot on your front wheel. That won’t happen on a 650c bike unless you have circus feet.
The business about 650c wheels climbing better seems to be true in my experience … but you have to be talking about a genuine climb for there to be any difference. Otherwise, the 700c wheels seem to carry more momentum into small hills and, if you’re geared right, you can get up and over rather quickly.
If you have two bikes set up identically except one has 650c wheels, you’re effectively turning your drivetrain into a compact. When you go to 650c wheels, you may want to go to larger chainrings. I run 56/44 on mine.
As for latex tubes, I buy Vredestein latex tubes and I cut them down and glue them back together to make my own 650c tubes. It’s very easy and works just fine. PM me for details if you’re interested.
Selections of wheels and tires are more limited in 650c, but there’s some very good stuff that’s readily available.
FWIW … I’m selling a P3sl 51cm/650c frameset and also a set of 650c Zipp tubular race wheels (404 and disc). PM me if interested. (I just built up an '09 P2 48cm/650c and I’ll race a HED Jet on the front and Renn 575 rear. SAWEEEEET!)
