How do you hide Di2 Components?
I have been looking at many of the posts and pictures here on the forum and I am not clear on the best way to hide the junction box on a Di2 setup. I have a BMC TM01 and Vuka Alumina Clips on Vuka Bars and Extensions. I am open to changing the base bars and extensions. What has everyone done?
Does that bike use an integrated stem?
The TriRig Sigma stem has a place to put the junction box
http://www.tririg.com/articles/2013_10_Liberty_Cervelo_S5_Review/960/2013_10_Liberty_Cervelo_S5_Review_33.jpg
Forgot to mention the BMC TM01 has an integrated stem.
maybe you can cut it up =)
Put the junction box inside the frame with the JC41.
-SD
when I saw your thread title I wondered if you meant “from the wife”
-SD
+1. OP, i used no fewer than 3 JC-41 boxes to wire my Plasma 3 TT internally. Definitely a bit Quixotic to say the least. Also, the EW-67 controller is not as readily accessible on this set up, but perhaps this thread i started could be of help. I should also add that the JC-41 is small enough that it could actually fit INSIDE some extensions.
http://forum.slowtwitch.com/gforum.cgi?post=4928130;sb=post_latest_reply;so=ASC;forum_view=forum_view_collapsed;;page=unread#unread
+1 on such setup
I have:
5-port SM-EW90-B by the battery compartment in the frame
2 SM-JC41 modules inserted into the headtube through the top slot (under the plastic cover) - each is connected to SM-EW90-B with one wire
everything is hidden
Yes, I don’t see you battery status indicator (I don’t think I care) and cannot clear electronically the protection function but there is (supposedly) a manual procedure for doing that
Charging\programming requires opening the battery compartment and plugging battery charger to easily accessible SM-EW90-B.
Works like a charm
That only requires hiding the receipt. :slight_smile:
