How do i post pictures to slowtwitch?
Hi all,
I have a classified ad posted, and seeing as how I am relatively illiterate with a PC, I cannot figure out how to post pics. Any advice would be appreciated.
Mike
I know I have posted a few different times on how to do this so the best way is to use the Search Button :wink:
Basically you go to tinypic.com—>upload the picture you want—>copy the image link not including the “IMG” tags at the beginning and end of the hyperlink.
—>Click the portrait button on the ST tool bar–>paste the IMG link and Voila you should have your image on your post.
My suggestion as well would be to write out you ad first and then hit return twice and then click the portrait button and insert the link from tinypic.com that way your picture is below your ad and that there is the appropriate break between the verbage and pic. Hope that helps and good luck with your ad.
thanks very much for the help
no worries and if that doesn’t work for you just PM me or email me and I can walk you through it or you can can send me the pic and I will post it for you and you can post you ad underneath it.
Best of luck with your classified.
worked perfectly, thanks again for the help.
Mike
