How do I measure my stem? (1)
Trying to figure out if my stem is compatible with a Vision Tech Carbon Base Bar. The base bar fits stems that are 26.0. Is that 26.o millimeters? And how do I correctly measure my stem to be sure?
yes, 26 mm…Put the cap on the stem, tighten the bolts to their normal position and measure. It will be plainly obvious if you have a 26 or 31.8 stem.
Bob
