How do I get the collar out of a 2005 QR Tiphoon frame Herbert?
I have a 2005 QR Tiphoon frame and I want to get the seat collar out of the frame so I can cut 4 cm of the aero seat post extension coming out the frame?,What is the best way of doing this Herbert?,or is it glued in?
anyone?
Why would you bother other than to have more seatpost showing
That’s what I want to do!!,like the new 2007 Tiphoon!!!
How are you planning on cutting the seat tube? Cutting/working with ti is difficult. I would contact Litespeed and see if they would do it for you, including moving the collar.
The collar is indeed glued in and quite difficult to remove plus I would also not recommend to cut the seattube without the correct fixture as we have it here.
I understand completely what you want to do, but would suggest that the frame comes back to us to get it done correctly.
Cheers,
Herbert
Quintana Roo
Thank you Herbert,that saves a expensive mistake!!!
Ouch. Does that mean to replace my damaged seat collar, I have to send the bike/frame to Chattanooga, my local QR dealer cannot perform this job?
Thanks!
  • Stephan
Stephan,
Your dealer should contact their specific inside rep here and get it handled from there. Typically it does have to come back, but that has to happen through the dealer.
The turnaround though is usually pretty quick.
Herbert
Quintana Roo
www.rooworld.com
The QROO blog
