Hot tubulars!
I got a rip in a tubular on last weeks ride and got round to fixing it on wednesday (spare bike + lazyness = no work on broken bits till the weekend!). So I glue the rim and new tyre without prestretching the tubular knowing its going to be tight as hell to get on but no time. I glue a second layer of glue on the rim this morning and then after reading how people used to stretch their tight clinchers i threw the tyre into the tumble dryer for 1 minute to get it nice and warm. After the heat the tyre was so easy to install it was a miricle, no sweating or swearing or mess.
Has anyone else tried heating their tubulars before fitting them???
I think you may be breaking new ground here - however I would rather break my fingers getting a tire on than risk the punishment of being busted putting a tire in the dryer. I an only imagine the wrath I would be subject to (even though I own the house and the dryer).
I put my tire in the direct sun to warm it up a bit…same concept as you but not so drastic. After I have properly glued and centered the tire on the rim, I pump that sucker up to the max and put the wheel/tire combo out in the direct sun again to get the glue all nice and warm and to allow both rim and tire to bond well. Little balls of glue will ooze out from under the tire…indication for me of a good bond.
I incurred no wrath from the god of the tumble dryer as I put the tyre in a ziploc bag, worked likeadream apoart from the ziploc got a bit stuck to a piece of tire. seems to work though
Awesome trick. Let us know if you suffer any ill effects fromt he dryer
The only side effect I can tell so far is the slight smell of bounce tumble dryer sheets on the tyre!
What about black tire marks on your white shirt that is next in line for the dryer???
I’ve actually considered this method for my new tuby disk. I have a process that I go through with new baseball gloves in which I dip them in warm water before wrapping them in a towel and putting them in the dryer, so I figured I could do something similar with the tires.
Water would be a bad idea unless the tire is in a ziploc bag or similar so water absorbtion does not deteriorate the bond. We put 33" teflon bands on pistons here at work so we actually have a full size pizza oven to use for the job so next time I am going to use the pizza oven for the job. I was just short of time and didnt want to mess about with this at work.
There are also rubber/ lead band heaters that would be perfect for the job but they are about $200
Although embarassing, mysterious black tire marks on your dress shirts can be much more easily explained than say, lipstick…
GB
