I’m looking at a new bike with horizontal dropouts and set screws for wheel adjustment.
I find myself wondering if excessive road vibration will move those set screws and result in a misaligned wheel? Anyone heard of this? Am I just being paranoid?
Theoretically, they could move. practically, never seen it happen
Have never heard of this happening either.
Ric
Not sure that would matter since once you put your wheel on and it is clamped those screws don’t really serve a purpose do they? I always thought they were just for getting the wheel on correctly and then beyond that, the quick release skewers hold it in place.
M~
Think “wheel change” and you’ll know why it’s important that they not move…
I understand that but I think the original question was dealing specifically with during riding.
Answers I’m glad to hear. I haven’t actually looked at one up close yet, but how do you know if both sides are even when setting them? Is it just “best guess” or is there actually a little scaled ruler type thing to set them on?
Put the wheel in and visually check that the wheel is centered between the chainstays near the bottom bracket, and is the desired distance from the seat tube.
throw a little lock tight on there and you shoudl be fine.
Sounds pretty easy and straightforward. Thanks for the help.
I’ve ridden a Litespeed Blade for the past two years and never had any problems with the set screws moving. BUT…it is really important to make sure you adjust them when you put on your race wheels. I’ll make everyone’s day here with what happened to me last year at Steelhead:
The race started like normal, I gave everyone a ten minute head start and then tried to catch them on the bike. The course was packed with riders and every time I would make a move to go around the packs I would get overtaken on the hills. I thought I was having an off day so at mile 15 I got off my bike to try and figure out what was wrong. I got a sick feeling when I noticed my rear wheel was too close to the frame and actually rubbing. We had to drop our bikes off at transition the day before the race and I completely forgot to adjust the set screws on the rear stays. I made the adjustment on the side of the rode and finished the race a little embarrassed by the rookie mistake. Oops.
I stand corrected ![]()
Been there done that. Same bike.
When I first got my bike I had problems with the wheel moving while I was riding, usually when i got out of the saddle to sprint or climb. I changed the skewer and all is good.
I have a P2K and the same thing happened to me at an OLY distance race, forgot to adjust screws for my disc and tire rubbed against the seat-tube. Lesson learned the hard way, won’t forget again!
I’ve never experienced the screws vibrating themselves out of position during a ride. As for making sure they’re even when adjusting, I eyeball the wheel in reference to the chainstays. Is there a better way?
Someone told me to count the number of screwdriver turns and make sure you do both sides evenly. When I did this the front of the wheel by the BB was slightly off center. I adjusted the one side until it was perfectly centered at the BB. Which is more important, that the wheel is centered at the Axle or at the BB?
