I am using a 5 port junction box with my Cervelo S5. I was trying to relocate it somewhere inside the frame. I already moved it from below the stem by hiding a junction b box into my internally routed Bontrager XXX aero handlebars. I tried to stick the junction box into my seat tube, but it barely doesn’t fit due to the mounting tabs.
I could probably sand it down but before I do that, is there a place where I could fit it?
How would I get the cable from the seat tube to under the saddle? The top about 4 cm of the seat tube is solid, not hollow, so can’t even drill the top part out and run a cable through.
ah, sorry; i thought the thickness may not be that large. this is the way some would hide their EW-90 boxes
also i have to say that i don’t think hiding EW-90 is a good idea on a road bike. On a TT bike, yeah sure, but with crashes more prevalent in a road race, you’d want to have quick access to reset your system in case something goes wrong.
also, other suggestions would be just above the bottom bracket, and using a EW-90 3 port and then use the JC-41 junctions to interface with the other wires
Stick it to the inside of the head tube where the top tube and down tube meet.
