Hey, fishies...help me interpret this workout please
If this was a track or bike workout, I could make some predictions, But I need help with this, since it is a swim workout. Here’s what I did yesterday:
500 free, 10x50 on 1’, 5x100 on 2’, repeat
S1=
8.25
47, 47, 47, 46, 46, 45, 45, 46, 45, 45
1.33, 1.34, screwed up, 1.33, 1.34
S2=
8.29
46, 47, 46, 46, 46, 46, 45, 46, 46, 46
1.33, 1.34, 1.34, 1.33, 1.32
What, if anything, can I take away from this kind of workout? I was tired at the end, but felt good. This is the longest workout, by far, I’ve ever done.
Thanks in advance for the help!
What was the question again?
Anyway, when using a test set, it’s helps to compare performances from previous workouts. Especially if it’s such a peculiar like this one. If you were asking about a T-30 or 5x400 with 10-15s rest, then I could help you.
SCY or LCM?
I’m assuming its short course yards and not real sure of your concern.
You seem to be able to hold pace consistently in your last set. Although total yardage is only 1,500. You might want to increase the yardage to help you w/ longer events. But, you should be fine if sprints are your target. (You will not be first out of the water, but should be in top 15 to 20% assuming you race above your training efforts.
If you plan on Olympic or longer races, you need to add yardage. And, I’ve actually found it is easier to hold interval pacing if you first develop some endurance in your swim. I did several weeks of 500 yard repeats at a controled ‘strict technique’ pace to develop endurance. Then addeded in the 10x100’s to develop speed. Reduced rest period to about 10 to 15 seconds between repeats.
Good Luck
Well, you’re basically even splitting your shorter repeats, but your pace for your 500s is about 5+ seconds slower per 100. That’s just the math.
As far as interpreting it, it’s hard to tell without knowing objective of the set. Where you trying to even split the 100s and 50s? If not, I would have expected some faster 50 times as compared to your 100 times.
Really depends on the intensity of the efforts. Also, hard to consider without comparing to previous workouts. Have you ever done an 800/1000 time trial?
Assuming your focus was on aerobic endurance, the :46 average for the 50’s translates nicely to 1:33 average for 100’s. Your 50’s need not have been faster based on the 100’s because you were only getting :14 rest on the 50’s compared with :27 on the 100’s.
These times would suggest a 400 pace of 6:28. This would translate to an 8:05 for a 500. So this may suggest your technique falters a bit in the latter stages of the 500. This of course assumes that this was the main set and was preceded by a good warm-up. If the first 500 was the warm-up and the second was recovery then forget what I just said.
Dan
i think you can take alot away from that workout…limited recovery time, and building up speed and strength…this will help you in wakey water, not to mention chase the guy down that punched you at the start.
By my math the yardage is 3000 not 1500, so I’d say at this point in the season you’re right on track- It is Feb you have a lot of time to build up yardage if you’re going long. Add about 250 yards/week over the next few months and you’ll be up to 5-6K by early summer and right on track for a IM.
I guess a lot of any analysis that anyone could give is to first ask what you were trying to accomplish and what are your goals for the year. Without that info it is hard to help.
But I also see that you seem to have only one speed and is is right around 47 sec/50. If you were doing a threshold set this would be fine, but I doubt you were since you did the whole work out at the same pace for 3K. IMO a better way to do somethng like this would be to bump the rest up just a tick. 5-10 more for the 50’s 10-15 sec more for the 100’s. Then try to descend each set, possibly doing the 10 50s as two sets of descend 5 (no rest between sets) continuous. Doing a set like this will not only make the workout go a bit faster becasue of the change of pace but also help with increasing your speed, and start to work different energy systems.
If your just looking to build a base and get general swimming fitness then move toward a bit longer distance sets say 200-500 repetes.
I agree about varying the pace a bit more, but I wouldn’t up the intervals that much. 27 seconds of rest on a hundred is appropriate if you’re going anaerobic on the set, but for aerobic conditioning purposes, I don’t like to see more than about 10-15 seconds of rest per 100.
What I’d experiment with is keeping the 50s on the 1:00 and throwing in some speedwork there- not all out hammering, but picking up the pace while keeping your stroke controlled. for the 100s, work on bumping down the interval to 1:45 or so while holding the same pace. Nice and strong, but still aerobic.
Yeh I like that also- Maybe 50’s descend, and 100’s tighter interval, no descend. Certanly a good mix of speed, aerobic and anaerobic.
As afar the interval goes 25’ish secs may seem like a lot, and I agree in some cases it is. But for a descend set if you want to really work on speed that amount of rest might be needed at this point in the season. In a month or two I’d the 15 ish sec resr/100 is right on.
Thanks everyone…for some answers:
  • 25 yard pool
  • purpose: 1) to survive, 2) to finish the second set equal to or faster than the first (**I’ve never done anything like this type of workout before)
  • I thought the rest interval was too long as well, but stuck with it for this time. I’ll shorten it next time.
  • Same speed…yes, that’s a problem for me, and I’m not sure how to fix it. But since the ultimate goal is an IM, maybe I don’t have to worry about it?
  • +++A+++ race is GFT in October, so I’ve got time. Swimming is very much my weakness, so any accomplishments I make (like yesterday’s workout) is major progress for me.
  • Not yet done a 1000TT, that’s in a couple of weeks
Thanks everyone who had feedback!
You don’t need to train like a sprinter, but a little bit of tactical speed is very helpful when it comes to manouvering in open water crowds, and getting to a spot where you can grab a a good set of feet.
For working on tactical speed, I’d go fart-lek- something like 6x125- each one 50 aerobic, 25 anaerobic, 50 aerobic. Get used to being able to throw in a quick burst of speed and then return to a normal aerobic pace without discomfort.
